Some disgusting pics
Old Jul 16, 2015 | 10:27 AM
Atomic's Avatar
I have a gauge for that
The leakdown numbers look ok for a performance engine IMO, but that sure is a lot of oil in the cylinders...
Old Jul 16, 2015 | 10:51 AM
George C....'s Avatar
Formerly ScreamingL
Originally Posted by DrX
Leakdown results on cold motor. After messing around with the gauge and slight variations in piston position on 1 cylindeer, I would say some of these numbers could be a few % high. Total seal 1.5mm stainless top ring gapped at .024 and 1.5mm Napier 2nd gapped at .024. 3mm oil.
GM service manual for a stock engine says leakage should be under 25%.
Some of the cylinders with the best numbers actually have the most crud on them.
1- 20
2- 20
3- 12
4- 12
5- 18
6- 18
7- 15
8- 20
1-20____2-20
3-12____4-12
5-18____6-18
7-15____8-20
never had a motor over 8% and when i did have one over 8% i had a bent rod in the hole....typically ive saw 2-5%
Old Jul 16, 2015 | 10:58 AM
DrX's Avatar
DrX
Guess it didn't help that the valve seals were getting hammered on the first go round. They look OK this time. But then again, the intake ports looked cleaner back then??? Petty brown/black now.
Old Jul 16, 2015 | 11:29 AM
Atomic's Avatar
Did you happen to do a leakdown test when the engine was fresh? It is most useful if you compare results over time.
Old Jul 16, 2015 | 11:32 AM
DrX's Avatar
DrX
No...should have.
Old Jul 19, 2015 | 05:25 PM
DrX's Avatar
DrX
100-200 miles and a few passes on these plugs. All on VP110.
Old Jul 20, 2015 | 10:08 AM
DrX's Avatar
DrX
Look at cylinder # 3 injector and plug.
ID1000s
Old Jul 20, 2015 | 01:45 PM
brandon6.0's Avatar
i see your ported heads have the rocker arm bolt holes open. they usually are like that with ported heads. did u use lock tight or thread sealer on those by chance? bc they will leak oil into intake runners without it.
Old Jul 20, 2015 | 02:43 PM
DrX's Avatar
DrX
I was thinking the same thing. Heads were assembled by the engine builder. I know I had a sealer for bolts like that when I rebuilt one of my outboard motors.
Old Jul 20, 2015 | 08:50 PM
1FastBrick's Avatar
Custm2500's Rude Friend
What kind of rocker arms are you using with those Bronze guides?
