Seriously..What CC dish do I need to get a comp ratio of 9.4-1 verification please
I am going to try and get some pistons ordered up for this 370 I am doing.. I am going to run 72cc heads along with a stock thickness head gasket. Shooting for about 15psi... I need to fig what cc dish I need. I am coming up with about a 6.1-7 cc dish on the stock ones, would keep that since that is what a stock dish is on a lq4, comp ratio is about 9.4-1.. Thanks and if you have any info you would like to shed me, please do. I want to make sure this thing is right.. Thanks
Yes, I screwed up, was goin off of the standard bore..
Thanks Joe for that. I thought the piston stuck up about 8 k out of the hole, with a deck height of about 9.24??
I would have no problem running 9.437.. I just gota make sure i get the dish right.. Correct me here also. The stock head gasket thickness is .051 correct.. Is that compressed or not.. This can really be a PITA. hahaha
The comp thickness of the stock gasket is .052. The other thing though John is I assumed that the pistons were .010 out of the hole. You should really measure though. My pistons were .013. The piston to deck height doesn't have as much of an effect though as the stroke, bore or piston cc dish. Play with the calc and you'll see
