ported ls6 heads vs stock ls3 heads
Old Oct 4, 2013 | 04:23 PM
TURBHOE's Avatar
Originally Posted by ZO6Ted
The exhaust on the LS3s are very limited without porting but if it lowers compression you could turn up the boost a bit. The turbo is gonna make the power anyway and its not like 9.8 is low but it probably would lose some low end due to larger ports of the LS3. Don't really think its worth all the trouble...not enough difference for all the hassle. Ported LS3s yes but not stock.
the ls3's wont really lower the compression it will raise it .3 from stock. the 5.3 had low 8.8:1 compression, i didn't like it near as much as the 6.0. it didn't have any bottom end compared to this motor stock. my cam is stock right now because the comp cam i had was shot. (wont buy from them again) i want to keep some good bottom end this time around, at 6020lbs i need it. makes the truck way more fun to drive around town. i figure if i did get the ls3 heads i would port and polish them. i heard tea had a good cnc for them but their site wont load so i don't know the cost on it.
Old Oct 4, 2013 | 05:21 PM
ZO6Ted's Avatar
Ok I understand now. I'll be putting my Patriot Stg 2's and a cam on this winter since I've already got them. BTW I've had 3 comp cams go flat over the years however, they were solid flat tappet lifters not roller. Your truck sure as hell runs good at that weight! It gives me hope on my HD. I weighed it at 5050 unloaded but 6020 like I drive it loaded.
Old Oct 5, 2013 | 04:10 PM
69Camaro427's Avatar
TURBHOE what psi were you running for the 5.3L time, that's impressive!
I had a buddy with an lq9 that put ls3 stock heads and intake from his camaro on it. It made a huge difference up top compared to the 243's but the 243's were a lot stronger every where except WOT
Old Oct 5, 2013 | 04:40 PM
TURBHOE's Avatar
the 12.33 run was just over 12 psi.
thats what i'm afraid of, at this weight i need more than just top end power.
Old Oct 7, 2013 | 07:13 PM
I know compression helps lowend and over all power, but how does one balance that CR# with boost# for best of both worlds. General answer please....I know this has many aspects depending on the application.
Old Oct 7, 2013 | 09:50 PM
black00chev's Avatar
Slowest turbo build ever!
depends on the fuel you are running and cylinder pressures. The higher the psi, the lower the cr you want. if you run a lower psi, the higher cr you can have.
Old Oct 7, 2013 | 10:05 PM
ZO6Ted's Avatar
I know a few yrs ago (2008) when I bought a built short block 9.5 was the accepted best compromise of cr with street boost on 93 and meth. That's what makes these stock ls motors so responsive to boost. I'm sure things have changed since then as technology keeps moving on. Still not a bad place to be.
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
bbowerman
Jul 26, 2015 10:57 PM
Suburban2500
Jul 19, 2015 04:50 PM
Aboss
Jul 9, 2015 10:28 AM
