Please tell me this isn't bad
Old Nov 9, 2010 | 09:09 PM
KDavis04ss's Avatar
Default Please tell me this isn't bad
Crank out of a 08 l76. 58 tooth reluctor wheel. how bad is it? sorry for the shitty pics.
Old Nov 9, 2010 | 09:13 PM
Coban's Avatar
I don't have first hand experience saying it will be OK but I wouldn't expect that to harm the signal. The sensor is just looking for the peak and valley...
Old Nov 9, 2010 | 09:23 PM
KDavis04ss's Avatar
I was thinking the same thing but I didn't know if it would disturb the signal.
Old Nov 9, 2010 | 10:06 PM
Bumpers's Avatar
While this is the subject.. What does the reluctor wheel do?
Old Nov 9, 2010 | 10:14 PM
iamkeniff's Avatar
it counts the rotations of the motor i think.
also you are building the motor dont worry with it. swap in a new 24x reluctor wheel and swap your timing gear, cam sensor, crank sensor over bam your done!
Old Nov 9, 2010 | 10:18 PM
KDavis04ss's Avatar
It goes along with the crank position sensor to let the computer know where the crank is to know when to fire the coils. I think.
Old Nov 9, 2010 | 11:40 PM
Mrgoodwrench3's Avatar
Need some better pictures and what exactly are you looking at. Any damage to the reluctor on the crank will cause problems. The PCM references the crank and cam signals for correct spark and fuel timing. I have seen the reluctor on the crank come loose and spin causing all kinds of havoc.
Old Nov 10, 2010 | 04:48 AM
Gadgetized's Avatar
How did this happen? It looks like you could get a signal out of it. I would try to put a little bead of weld on it, and grind it back to shape.
Old Nov 10, 2010 | 11:13 AM
iamkeniff's Avatar
its a L76 therefore its a 58x. he's got a 24x so just swap the reluctor wheel to a 24x and forget about it simple fix, dont worry with it.
Old Nov 10, 2010 | 11:22 AM
budhayes3's Avatar
PT's Slowest Truck
The PCM also uses the crank sensor signal to help determine misfires. It looks at crankshaft speed, and if it sees the crank slow down when a certain cylinder is firing it will trip a misfire code.
