Piston to valve clearance
Old Aug 8, 2011 | 09:11 PM
2DOORFOOLER's Avatar
Default Piston to valve clearance
I have a 2006 stock 6.0 engine that came off a escalade that i will start messing with soon...I would like to know whats the max cam lift i can use if i run some 243 heads milled down to 30 thousands...
Old Aug 8, 2011 | 09:29 PM
Chevy_King1500's Avatar
What are your plans for the truck? strip, DD, weekend play toy? What transmission are you running? The biggest cam you can stick in there will suck with-out the right converter.
Old Aug 8, 2011 | 09:33 PM
Atomic's Avatar
I have a gauge for that
I would get a dial indicator and find out first hand... PTV clerance isnt something you want to leave to chance...
Old Aug 8, 2011 | 09:38 PM
budhayes3's Avatar
PT's Slowest Truck
+1, and you really need to look at all of the cam specs, not just the lift...
Old Aug 8, 2011 | 09:49 PM
Atomic's Avatar
Yep...closest piston to valve occurrence is usually about 10-15 degrees ATDC when the cam (and valve) is far below max lift.
Old Aug 8, 2011 | 10:03 PM
Default ptv
its going to be just a weekend toy. i will be running a built 4l60e...
Old Aug 8, 2011 | 10:07 PM
I have not pick out a cam yet because iam getting my 243s ported at a local shop...i want to know the flow numbers on them first and then from their iam going to get a custom cam an then a matching stall for my combo
Old Aug 10, 2011 | 11:29 AM
1slowz71's Avatar
Like said b4 PTV does not happen at max lift you must look at LSA and ICL as well
Old Aug 10, 2011 | 12:44 PM
TXsilverado's Avatar
are you willing to flycut? lol. talk to a professional and let them spec you a big cam that will fit.
FlyingLow
Nov 24, 2015 10:05 AM
zblee
Nov 11, 2015 12:41 AM
11MPG
Sep 8, 2015 04:52 AM
bisqikss
Sep 8, 2015 03:35 AM
