oil priming a ls1 motor
I also turned the motor over with the coils unplugged and fuel pump relay out in my 408 build. It took a few cranks before it showed oil pressure but it worked great for me. Good Luck
If your not going to use a "professional" method or tool then i would deff use the methods like said above, byunplugging the coils or the fuel pump relay and crank it over until your oil pressure guage begines to move in the cluster.. then plug everything up and fire it up..
when the engine is cranking it is spinning the oil pump, inturn working the oil pump..
