oil priming a ls1 motor
Old Jan 20, 2012 | 10:59 PM
Half-bred's Avatar
Default oil priming a ls1 motor
Is there any way to oil prime a ls1 motor? I want to do something before I start it up after my rebuild.
Old Jan 21, 2012 | 12:31 AM
moregrip's Avatar
what a rush!
I used the kent moore pump kit to prime mine
Old Jan 21, 2012 | 02:43 AM
nonnieselman's Avatar
Ive just unglugged the coil packs and spun it over bout 15 seconds a couple times. Then plug the coil packs in and fire it up. Should have oil pressure pretty quick.
Old Jan 21, 2012 | 06:45 AM
TXSZ66AVLANCHE's Avatar
The assembly lube keeps everything lubricated until oil starts flowing. All the rebuilds I've done the OP builds up really fast, just like a oil change.
Old Jan 21, 2012 | 01:40 PM
01silvy's Avatar
You have to be careful about turning the engine over too long without it running.. ive heard than can collapse lifters and make them pretty noisy for a few minutes..
Old Jan 21, 2012 | 06:07 PM
oakley6575's Avatar
I also turned the motor over with the coils unplugged and fuel pump relay out in my 408 build. It took a few cranks before it showed oil pressure but it worked great for me. Good Luck
Old Jan 21, 2012 | 09:02 PM
01silvy's Avatar
If your not going to use a "professional" method or tool then i would deff use the methods like said above, byunplugging the coils or the fuel pump relay and crank it over until your oil pressure guage begines to move in the cluster.. then plug everything up and fire it up..
Old Jan 21, 2012 | 09:32 PM
Half-bred's Avatar
OK Thanks for the info I will do that. I'm hoping to get it running this week some time.
Old Jan 21, 2012 | 10:20 PM
01silvy's Avatar
Keep us posted and let us know how it turns out.
Old Jan 21, 2012 | 11:56 PM
Mangled03gmc's Avatar
Baltimore Whore
when the engine is cranking it is spinning the oil pump, inturn working the oil pump..
