Noob cam advice
Old Mar 1, 2016 | 10:01 PM
  #31
Wolftrk99's Avatar
If you go to btr's website they have a cam suggestion/recommendation worksheet will cost you $20 but they take it off the price of the cam...
Old Mar 2, 2016 | 01:22 PM
  #32
mr.dudeman199's Avatar
Yeah I had seen the worksheet on their site, wasn't sure what it was all about. But yeah if they take it out off the price of the cam anyway I will do that
Old Mar 2, 2016 | 02:59 PM
  #33
Wolftrk99's Avatar
They do... Cams are 389 i went through the worksheet ended up pying $369 for the cam...
Old Mar 2, 2016 | 08:51 PM
  #34
Is this the right plug? It's right behind the crank pulley on the driver's side of the crankshaft.
Old Mar 3, 2016 | 01:44 AM
  #35
Wolftrk99's Avatar
Yep thatd be the vvt/cam sensor plug
Old Mar 3, 2016 | 08:48 AM
  #36
Well that brings up another question then, do I delete the vvt or keep it like kazfan said and get a vvt cam? Being I'm going turbo down the road I want as much low end as I can get, but I don't want to sacrifice a good lope. In all honesty if I had to decide between low end grunt and a good lope I could deal with it being a pooch down low.
Old Mar 3, 2016 | 08:59 AM
  #37
Wolftrk99's Avatar
From my understanding boost and vvt are a pain... If you are planning on boost later delete the vvt and get a higher stall converter
Old Mar 3, 2016 | 09:15 AM
  #38
Sounds like a plan
Old Mar 3, 2016 | 09:55 AM
  #39
Wolftrk99's Avatar
Make sure when you swap the cam to check the bearings really well, and be ready to replace them if necessary
Old Mar 3, 2016 | 09:58 AM
  #40
Will do. What do I look for? Will the cam show signs of it?
