Need buildup advice for FI motor.
Old Nov 8, 2005 | 08:22 PM
  #31
treyZ28's Avatar
i think you need to sell what you have and get an LS7
Old Nov 8, 2005 | 08:42 PM
  #32
I know my 15lb pulley will no longer make 15lbs. I could care less how much boost i make as long as i'm making lots of HP. I still say i should just do heads and cam on my current motor but everyone says the rods won't hold up and neither will the pistons. Heads and cam will cost $3000 installed and tuned. But, if i'm gonna break the rods or melt the pistons, what's the point? Changing the pistons and rods will probably cost at least $3000 i think. So now i've spent $6000 and still have a 6.0L. Is that the route I should go? I think I can use my stock fuel system that way. I should be able to be over 500rwhp with heads, cam and headers on my current motor and boost.
Old Nov 8, 2005 | 09:23 PM
  #33
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If it was me I would find a cheap 6L block get it bored/honed drop a forged eagle rotating assembly(i can get it for 2200) Do a valve job on the heads put a good set of springs on it and a cam=4grand plus whatever it is for install and tuning. Believe it or not you can do the install/removal yourself if you have a place to do it.
bearden86
26
Nov 15, 2015 03:58 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
Chevy305
Sep 28, 2015 09:21 PM
Cha_Feel_
Sep 23, 2015 09:06 PM
