Need 5.3 cam/heads info
Old Jan 27, 2014 | 01:38 AM
Chrgd00seirra's Avatar
Registered User
Default Need 5.3 cam/heads info
I got a 01 5.3l im trying to get about 425whp out of ..i do have a procharger i plan to put on it but not sure on how to choose my cam and/or heads...anyone help me out on thia budget build
Old Jan 27, 2014 | 08:34 AM
Vortec350ss's Avatar
If you already have the procharger then 425 will be easy as pie.
It all depends on what you are after, and what you are willing to sacrifice. How do you use the truck? How many miles per year?
There is someone selling a GT2-3 on here which is a great MILD boost cam if that is what you are after. Couple that with a 3000 converter, 8-10 PSI, and a set fo headers and you should have good manners with 425 hp to the wheels without even touching the heads.
If you are willing to get a little more aggressive something like a vinci trucker will give you much more mid range while giving you a more lumpy idle.
With goals like that there is no need for a head swap if you have a procharger.
Old Jan 27, 2014 | 05:08 PM
Registered User
The procharger puts about 5lbs to the motor .... the truck is a 5spd 2wd .... just looking for a kind of choppy idle .... it has headers and obiously ill be putting a good tune to it
Old Jan 27, 2014 | 07:36 PM
craigsix's Avatar
everybody on here seems to be on a budget build. you gotta pay to play.
Old Jan 27, 2014 | 08:13 PM
Registered User
Hence why im not looking for crazy horsepower
Old Jan 27, 2014 | 08:20 PM
Just buy a different pulley and up the boost a little. you will be much happier in the 8# range. I think the vinci trucker is right in your wheel house.
Old Jan 27, 2014 | 08:38 PM
Registered User
Thanks ill be looking into them... i had a buddt tell me the comp cam kit is a good wsy to go but is that too much for stock heads?
Old Jan 30, 2014 | 01:47 PM
69Camaro427's Avatar
I have a buddy with the 210/218 on 112 from vinci in his N/a 5.3L and it has power all over the place and really wakes up top. So I agree on the vinci trucker cam being a good choice. I wouldn't say it is chopy, but has a nice consistent lope to it.
The stock heads are going to give you plenty of tq with those small runners also. There are tons of boost guys making over 500whp with the stock 5.3 heads. The stock heads are maxed on flow around .550-570ish
Old Feb 2, 2014 | 09:08 PM
Registered User
Oh damn ok thanks! But with different cams everyone says i have to do springs and rods...is that true? I was looking at a 212/218 comp cam as well
Old Feb 2, 2014 | 09:22 PM
batboy's Avatar
11 Second Club
Yes, you need to upgrade valve springs and pushrods.
