Need 5.3 cam/heads info
I got a 01 5.3l im trying to get about 425whp out of ..i do have a procharger i plan to put on it but not sure on how to choose my cam and/or heads...anyone help me out on thia budget build
If you already have the procharger then 425 will be easy as pie.
It all depends on what you are after, and what you are willing to sacrifice. How do you use the truck? How many miles per year?
There is someone selling a GT2-3 on here which is a great MILD boost cam if that is what you are after. Couple that with a 3000 converter, 8-10 PSI, and a set fo headers and you should have good manners with 425 hp to the wheels without even touching the heads.
If you are willing to get a little more aggressive something like a vinci trucker will give you much more mid range while giving you a more lumpy idle.
With goals like that there is no need for a head swap if you have a procharger.
I have a buddy with the 210/218 on 112 from vinci in his N/a 5.3L and it has power all over the place and really wakes up top. So I agree on the vinci trucker cam being a good choice. I wouldn't say it is chopy, but has a nice consistent lope to it.
The stock heads are going to give you plenty of tq with those small runners also. There are tons of boost guys making over 500whp with the stock 5.3 heads. The stock heads are maxed on flow around .550-570ish
