Motor is apart what should i do?
Old Apr 26, 2010 | 03:18 PM
SUX2BU's Avatar
11.0 Moderator
Default Motor is apart what should i do?
So, #2 exhaust lifter got chewed up along with the cam. LQ9 has almost 100k miles so I'm gonna go through it.
Obviously, I'm getting a new cam, oil pump, lifters, gaskets, rings, bearings, blah, blah blah.
But my question is should i go ahead and do forged pistons and rods? Head studs?
I will be keeping the stock 317 heads with patriot springs. Will probably not be running much boost maybe 10 psi max but probably more around 7 psi. So will stock pistons and rods be ok or should i spend the extra $$ and go forged? I will be building the motor myself. Its a Turbonetics T-76 turbo and a freshly built 4L65E in a big *** Escalade ESV.
Old Apr 26, 2010 | 08:48 PM
2toneblown's Avatar
Stock **** should be fine. I ran 15#s and a 75 shot on my 05' with the stock motor for a good while. So if your only gonna run 10#s then stock ****. My 07' has rods and pistons with head bolts with 12#s but wanting to turn the boost up but cant get a tranny to hold up. Bullshit 6L80. I wana swap to a 4L80
Old Apr 26, 2010 | 09:18 PM
acethedragon's Avatar
funny. i know the 6l80e is a relatively new tranny but companies are making hd parts for them and should be able to build it up as tough as the 4l80e. wish you luck with it
Old Apr 26, 2010 | 09:39 PM
Atomic's Avatar
I have a gauge for that
arp rod bolts
Old Apr 26, 2010 | 09:55 PM
2toneblown's Avatar
I dont know of anyone making hard parts. I have already had RPM Transmissions build it but i have only found people that only have upgraded clutches. So if you have any info please let me know. Keeping in mind that my truck weighs 7800#s which is about double that of a camaro or corvette that these companies are building these trannies for
Old Apr 26, 2010 | 10:04 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Check with Circle D they ARE making hard parts, what the ETA on them is I dont know...
Old Apr 26, 2010 | 11:47 PM
2toneblown's Avatar
I have already talked to them aswell
Old Apr 27, 2010 | 03:04 AM
Spoolin's Avatar
GFYS and STFU
I'd would think that if you know your not gonna go past 10lbs of boost you could stick with the stock pistons and rods, unless you know your gonna throw more boost at it at some point. I would do ARP studs for the heads though.
Old Apr 27, 2010 | 11:45 AM
SUX2BU's Avatar
11.0 Moderator
Yeah i would love to build it to handle plenty of boost, but i know i would end up in Ryan's boat of having lots of power with no tranny to hold it combined with the weight of my boat.
Old Apr 27, 2010 | 10:07 PM
silver-mod-o's Avatar
Hunt&Fisherator
I'd do good pistons on stock rods and crank. ARP rod bolts, mains and head bolts would be on the list too... No need for studs in anything less than 18psi-ish...
