Max Bore and Stroke
Old May 15, 2007 | 03:02 PM
damon0311's Avatar
Registered User
So will the crank and rods fit...before i start to put everything together.
Old Jul 16, 2007 | 06:25 PM
SS_bnoon_SS's Avatar
The 99mm pistons will fit once you bore your stock block out to match them, Your stock bore is 96mm if I remember right...
The 4" stroker crank will fit as long as the pistons you got are made for a stroker, or you use shorter than stock rods. If you tried to use stock 5.7 pistons that are made for a 3.622 stroke crank (I believe that's the stock stroke) with the 4" stroke crank, your pistons would pop out of the block at the top of the stroke.
lukn4trbl355
Oct 21, 2015 11:19 PM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
2plus2
Sep 13, 2015 07:17 PM
Forcefed81
Sep 8, 2015 10:02 PM
