cam for 5.3l and stall converter?
Old Jul 14, 2007 | 02:53 PM
edgarglz84's Avatar
Banned
Default cam for 5.3l and stall converter?
hey guy's i'm ready to install a cam on my 5.3l in about a week or two.i want to know from ya'll what's a hell of a good cam for the 5.3l and plus stall and tranny work.right now the truck has a 93 octane tune,flex alite e-fans,k&n intake,asp pulley,hooker super comp lt's with hooker ory,borla xr-1 sportsman 3" in and out single all the way to the back with a borla tip 3" in and 3 1/2" out,slp thermostat 160*,throttle body spacer,port and polished throttle body,corvette servo,and the gears are 3.73's.any suggestions from ya'll than can help me make this truck run good.oh yeah and it's a daily driver kinda.only from work and back most of the time.if you got vid's post them up so i can here some idle clips.thanks guy's.
Old Jul 14, 2007 | 03:02 PM
nightrunner's Avatar
Mr. Obvious
what size stall is it?
do you want a torque/bottom end cam or one for top end and rev over 6krpm?
Old Jul 14, 2007 | 03:08 PM
edgarglz84's Avatar
Banned
sorry if i put on there that i had a stall.right now i don't i have the stock stall on the truck.what i ment is that what stall should i go with the cam.i want a buttom end.what do you recomend?
Old Jul 14, 2007 | 03:12 PM
Mr. Obvious
personally id call or pm richard@WCCH for a custom ground cam.
id think something like a 216/220 on a 112 w/ around 550s lift
Old Jul 14, 2007 | 03:38 PM
edgarglz84's Avatar
Banned
who is he?.is he someone from comp cams or somewhere like that?i have a buddy here in pasadena "flaco3rdgen" i think he can order custom grind cams.he told me the same thing "custom grind".i really want to set my truck to run a constant low 13's in good weather and also somewhere in high 12's.where is he located?good friend of yours?
Old Jul 14, 2007 | 03:40 PM
edgarglz84's Avatar
Banned
http://s180.photobucket.com/albums/x...t=Trake012.flv.
that is his truck!!!
Old Jul 14, 2007 | 03:59 PM
Flaco's Avatar
8 Second Club
edgar go with the 228r from tsp and a 3200 stall, call me
Old Jul 14, 2007 | 04:08 PM
Mr. Obvious
richard@WCCH owns and operates a CNC head porting business and is now known for his engine building. he can get any grind of a comp cam you want, and will tell you what will work best for your specific application. he also sponsors this site and helps keep it running.
IMO i dont think you will not like the TSP 228R, no matter what size stall you get, especially in a crew cab. the 228R is NOT a bottom end cam but with a large enough stall you wont notice it
Old Jul 14, 2007 | 04:19 PM
onebadrubi's Avatar
The 228 is alot of cam for a 5.3l. It would require atleast a 3600 stall to get optimal performance.
I would think something around the 212/218 high lift cam with a 3200 stall will get you close to what you want. Will provide great hp and torque from 2800rpms to 6200 rpms.
Old Jul 14, 2007 | 04:44 PM
bluecajun5.3's Avatar
11 Second Truck Club
go with the 228 geeze don't listen to these people
