Max Bore and Stroke
Old May 9, 2007 | 04:56 PM
damon0311's Avatar
Registered User
Default Max Bore and Stroke
I have a 05 Serria, I have 99mm pistons, now I just got as a gift, a 4.000 crank (forged steel) and new rods 6.100, will it fit in my 5.3L block. I know the pistons fit, wondering if the crank and rods will go in and if not what need to be done. What kinda cam do I use.
K&N Intake, Granatelli Mass Airflow Sensors, Throttle body spacers, throttle body, Shorty Headers, flow master exhaust, New PCM by nelson performance.
Old May 9, 2007 | 05:54 PM
seeyaa's Avatar
the crank will fit,not sure about the rods however save your cash and stroke a 6 liter they a 4.00'' bore that will make it rip
Old May 9, 2007 | 07:55 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The 6.100 rod makes me think you have parts for a SBC not a GENIII motor. The normal rod for a stroker motor is a 6.125. What does 99mm equate to in inches Im lazy
Old May 9, 2007 | 10:51 PM
kbracing96's Avatar
3.897638
Old May 10, 2007 | 12:50 AM
PappyDan's Avatar
Tribe Shaman
Originally Posted by kbracing96
3.897638
that looks like a stock 5.7 piston size.
Old May 10, 2007 | 04:04 AM
viciousknid's Avatar
Where's the Beef?
How does someone just buy you random engine parts as a gift? Why not just hand you cash and give a pat on the back.
Hey bra, I got you a new set of pistons for your rx8! check'em out!!
Not trying to be rude or anything, It's just not a gift you wana guess at.
(obviously rx8 doesn't have pistons)
Old May 10, 2007 | 11:04 AM
Quik's Avatar
5 year bitches!
easy sounds like a tool that is starting crap on this site. look at his post carefully. someone says MM for a piston its usualy a ricer
Old May 10, 2007 | 12:37 PM
blown3qtr's Avatar
LMAO
Old May 10, 2007 | 12:55 PM
damon0311's Avatar
Registered User
Default Thanx
Piston sizes is 3.905, Rods are 6.125, my brother had a 5.7L GTO was going to bore and stroke it instead bought a 402 long block for it instead. I bought the pistons myself before I got the new parts to make my 5.3 into 5.7.
Old May 13, 2007 | 10:14 PM
Where's the Beef?
I see.. You got them for him but he changed his mind and let you keep them, now you wana build up.
That I can understand.
