ls6 spring identification (again)
Old Mar 23, 2008 | 12:50 PM
custom 68's Avatar
Default ls6 spring identification (again)
I am doing a cam and spring swap. I bought some spring used a year or so back and understood they were 04 or 05 ls6 springs. they have a light orange stripe on them.
the ones I am removing from my stock 5.3 heads look vurtually identical they have a dark orange stripe. I have measured them and compared the wire diameter and heights they look identical. did I get teh wrong springs or can you tell. unless I hear differently I will probably order the yellow ones to be sure I just wish I knew.
any thoughts?
Thanks
Dave
Old Mar 23, 2008 | 01:08 PM
Tootall's Avatar
if it has the orange stripe . . . then they're stockers. . .
LS6 springs are a solid blue or a solid yellow
Old Mar 23, 2008 | 02:33 PM
hirdlej's Avatar
Or babyshit green. The solid blue springs are good up to a .550 lift I'm told and the solid yellows and babyshit green ones are good up to .560-.580 lift depending on the severity of the lobe ramps.
Old Mar 23, 2008 | 02:53 PM
BlownChevy's Avatar
blownerator
25 Year Member
If you can, upgrade the springs to the 918's (minimum). I went through a set of LS6 springs within 25K.
Old Mar 23, 2008 | 04:06 PM
custom 68's Avatar
ok thanks guys I assumed they were stockers, I bought them a while back before I knew much about these engines, but after Ilooked at them I decided it was not worth taking a chance if there was any question and you all answered as expected.
my cam has a lift of .566, LPE suggested tthe ls6 springs but I will rethink the 918 again.
Not a huge setback maybe next week it will be running again...
thanks
Dave
Old Mar 23, 2008 | 06:12 PM
hirdlej's Avatar
If you're using the LPE cam (assuming a gt2-3) or similar the lobes on those cams are very gentle. Go with the LS6 yellow springs like they prescribe. They know what they're talking about. Don't use a 918.
Old Mar 23, 2008 | 08:09 PM
custom 68's Avatar
gt2-5
222 222 .566 .566 112
pm sent...
thanks
Old Mar 23, 2008 | 08:37 PM
BlownChevy's Avatar
blownerator
25 Year Member
I have more than likely installed and sold more GT2-3 cams in the last two years than LPE has. I have the GT2-3 in my truck, and in a matter of 20-25K with boost the springs were butter. I am not saying LPE does not know what they are talking about, but if you want to MAKE SURE you do not have an issue.....Get an after market spring like the 918's or patriot golds.
1989k1500
Nov 2, 2015 05:16 AM
zblee
Sep 19, 2015 06:33 PM
vipergtrdj
Sep 11, 2015 05:52 PM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
screaminian47
Sep 7, 2015 08:20 PM
