LS6 Heads on a 6.0?
Old Dec 15, 2006 | 12:11 PM
Default LS6 Heads on a 6.0?
I have a 02 gmc with a 6.0 all stock engine. I'm wondering what i could gain changing over to say LS6 heads to raise the compression. Anyone done this? Is it worth it?
Old Dec 15, 2006 | 12:56 PM
Zick's Avatar
You'll gain about a full point in compression. What do you have a LQ4 or LQ9?
A LQ4 would be about 10.5:1 and LQ9 would be 11:1.
Unless you have access to tune the timing correctly you will have to run premium on a LQ9 and even then you may run into detonation problems.
My old setup was done all at once so I can't say how much it helped, plus I had ported heads too.
Old Dec 15, 2006 | 05:29 PM
I have a LQ9 6.0.
Old Dec 15, 2006 | 06:12 PM
Quik's Avatar
5 year bitches!
i ran 243s on a Lq9 and it was at 11.1cr on a Lq4 its 10.5
Old Dec 21, 2006 | 10:47 AM
Thanks for the info!
Old Dec 21, 2006 | 02:36 PM
Sierra1sh's Avatar
Dave,
I have an 02 GMC and I'm thinking of dropping an LQ9 in it.
What mods did you have to make?
Thanks,
Jerry
Old Jan 2, 2007 | 12:30 PM
ap2002's Avatar
was this stock 243's??
Old Jan 2, 2007 | 04:05 PM
Quik's Avatar
5 year bitches!
yes unmilled 243s on a LQ9 makes it iron block LS2. difference is 10.9 to 11.1 difference between the iron block and aluminum block. same internals
Old Jan 5, 2007 | 10:55 AM
OnyxSilveradoSS's Avatar
that a good way of putting it so I can understand.
The_W
Oct 28, 2015 09:00 PM
greedygenius
Sep 3, 2015 06:51 AM
Verz
Aug 21, 2015 06:40 PM
darnie
Aug 10, 2015 10:25 AM
Aboss
Jul 9, 2015 10:28 AM
