LS1 crank
Old Dec 7, 2010 | 07:25 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Same crank, even the same casting number. Balanceing is specific to each application though. LS1 version Is gun drilled right down the center of the mains and thats the difference. I have seen people throw truck cranks away thinking there useless and that an Ls1 crank is some how better. Personally I would rather have the truck crank. It is less like to bend esspecially after reworking it....
Old Dec 7, 2010 | 07:45 PM
1Bear's Avatar
Yep, casting # 12552216 for narrow flange cranks in 5.3L, 5,7L & LQ4/9 6.0L’s.
Old Mar 15, 2011 | 02:42 PM
Y@ BoY p@Ul's Avatar
Whats up guys. So how much difference is there between the stroke and bore of a 5.3 an ls1 ?
Old Mar 15, 2011 | 04:30 PM
slow67's Avatar
Gingervitis Addict
Stroke is the same, 5.3 bore is 3.78, ls1 bore is 3.898
Old Mar 15, 2011 | 06:49 PM
Okay i thougth the stroke was the same. What about compression ? ls1 is a lil higher right ?
Old Mar 15, 2011 | 10:31 PM
slow67's Avatar
Gingervitis Addict
Run of the mill iron LM7 5.3L is 9.5:1 and LS1 is 10.25:1
Old Mar 15, 2011 | 11:22 PM
kazfan30's Avatar
High compression 5.3 here!! 4.8 pistons in a 5.3 all day, a whopping 400.00 investment as a whole and running strong. My compression is 10.3:1 with MLS and 706s
Old Mar 15, 2011 | 11:30 PM
Beatdown Z's Avatar
Laid Back
Originally Posted by kalikid06
Good to know, thanks. If I were to do this tho, I would find some 5.3L rods and pistons tho cuz I'm not crazy about high compression....I like boost.
If my turbo 5.3 goes boom, I may give these guys a call: https://ls1tech.com/forums/forced-in...ck-2599-a.html
RustyD
May 23, 2016 07:04 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
trxmxzx
Sep 29, 2015 07:42 AM
FormulaZR
Sep 14, 2015 05:23 PM
