LS1 crank
Old Dec 5, 2010 | 10:41 PM
kalikid06's Avatar
Default LS1 crank
Is an LS1 crank really the same as a 5.3L crank?
Old Dec 5, 2010 | 11:02 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
yup same stroke 3.622 i think the ls1 crank might be alittle lighter then the 5.3
Old Dec 6, 2010 | 12:53 AM
stock48's Avatar
9 Second Truck Club
Ls1 cranks are gun drilled, and the truck 3.622 cranks are solid. At least from what I've seen.
Old Dec 6, 2010 | 06:12 PM
acethedragon's Avatar
bobweight is a little different too cause of the larger bore/piston of the ls1 over the 5.3
Old Dec 6, 2010 | 07:05 PM
kalikid06's Avatar
So theoretically an LS1 crank can be used to stroke a 4.8L ??
Old Dec 6, 2010 | 08:22 PM
1Bear's Avatar
Yes, with the stock length non-floating pin rods from any other Gen III, you could use the LS1 crank with your stock 4.8L pistons to basically build a higher compression 5.3L. I would have the rotating assembly rebalanced when mismatching components however.
Old Dec 6, 2010 | 08:54 PM
kalikid06's Avatar
Good to know, thanks. If I were to do this tho, I would find some 5.3L rods and pistons tho cuz I'm not crazy about high compression....I like boost.
Old Dec 6, 2010 | 09:07 PM
offroadrider12's Avatar
If going to all that work why not bore the block out to make it a Iron ls1 instead of a hi comp 5.3?
Old Dec 6, 2010 | 09:40 PM
1Bear's Avatar
The only reason I see to do it would be for a bucks down build if you already had the parts lying around. Replacing the pistons, yes I would go ahead and bore it out to stock LS1 size if the particular block would take it. For a build that needs it, there isnt a substitute for forged pistons; however for a decent upgrade over stock truck pieces, even stock LS1 hypereutectic pistons are slightly better than the factory cast pieces and if picking up all the pieces from say a damaged LS1, you could build an iron version without the re-balancing.
Old Dec 6, 2010 | 09:44 PM
53RUSSELL's Avatar
I had stock 5.3 crank in my ls1. The ls1 crank that came with my ls1 was no good.
