LQ9 Oilpan...only a dealer avail item?
Old Feb 5, 2007 | 02:17 PM
dhpro's Avatar
Default LQ9 Oilpan...only a dealer avail item?
I'm being told there's no aftermarket item that works...is this possible? I've bored it out to 4.050 to build a 370 and wanted to use a littel bigger capacity shallow pan...any recommendations? R/
Old Feb 5, 2007 | 10:26 PM
onebadrubi's Avatar
ls7 OIL pan. Since your 4x4 I dont know if it will clear.
Old Feb 6, 2007 | 12:07 AM
LS7 is dry sump no oil capacity in pan uses a dry sump tank.Just add a oil cooler to the stock system.
Old Feb 6, 2007 | 12:47 AM
2004SSS's Avatar
your going to get more than a 370 with 4.050 unless your using a 4.8 crank. that a bit bog imo what are the cylinder wall thickness's?
Old Feb 6, 2007 | 06:33 AM
dhpro's Avatar
[QUOTE=2004SSS]your going to get more than a 370 with 4.050 unless your using a 4.8 crank. that a bit bog imo what are the cylinder wall thickness's?[/QUOTE
Right...typo...4.030 is 370, right? 4.050 is 383?
Old Feb 6, 2007 | 10:55 AM
12secSS's Avatar
You can look at the Canton or Moroso oil pans. Any Gen3/4 oil pan will bolt up to your 370. The trucks have a deeper sump vs. the car models like the F-Body. It should hold 7qts just fine. You will not need any more.
Old Feb 6, 2007 | 12:53 PM
Quik's Avatar
5 year bitches!
i think a .050 over is a 374 or 375 since a .060 supposed to be a 377 like the 6.2s
Old Feb 6, 2007 | 04:27 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I would add in a large oil cooler with 1/2" lines or larger and you will get another quart or two plus additional cooling which IMO is better then just ahving added volume unless you are doing some rock crawling stuff then you need dry-sump.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
old motorhead
Sep 29, 2015 08:22 PM
