LQ4 turbo build
Old Jan 4, 2019 | 11:23 PM
Jseal52's Avatar
Default LQ4 turbo build
Hello I’m looking to build up a lq4 to replace my 4.8 in my rcsb. The plan for the 6.0 is replace all the bearings on the crank and use the stock crank then upgrade the rods and pistons. Want to put a BTR stage 2 turbo cam with ls7 lifters and ls9 head gaskets. Then upgrade all hardware to studs. Only thing I’m not to sure about is what to do with valve springs, rockers and heads. Would like to use stick heads and just upgrade what I can. Can I use factory rockers? Also what is a good replacement for throttle body as my truck is a drive by wire.
Old Jan 5, 2019 | 06:35 AM
arthursc2's Avatar
That's a lot of questions lol.
Heads:
Stock is fine, maybe clean up in the bowl if you want
Stock valves are fine provided the margin is enough to get a valve job done
I like PAC 1219 springs, personally
Stock rockers with trunion upgrade
Lifters:
Johnston 4110s are nice, just saying
Rods:
Gen4
Pistons:
Gen4 compatible, make sure you get your CR where you want it. I'd personally do a .03 over
Cam:
get the bearings replaced
Crank:
cut it .01
Studs:
dont stud the mains without planning to have them linebored
ARP head bolts will get you to 700hp no problem. Ebay head studs have proven their own too. I'd buy ARP bolts before I bought ebay studs, but I have a chip on my shoulder to use brand name stuff
Oil pump:
lots of opinions out there. I use the Melling pump with the yellow spring. Properly shimmed on install. Get your self a set of feeler gauges, you'll need em
thats all I can think to say man, good luck!
Old Jan 5, 2019 | 10:18 AM
Jseal52's Avatar
Thank you very much. That helped a bunch. I’m trying to do a budget rebuild but get some reliability outta the motor. Looking to get 600whp and just beat on the thing and drive it almost every day.
Old Jan 5, 2019 | 11:49 AM
Jseal52's Avatar
Also what about intake and throttle body? How well would the factory ones work?
and lifters do you mean 2110's?
Old Jan 5, 2019 | 12:05 PM
arthursc2's Avatar
Yes I do, I'm sorry. I used the 2110R in my 408.
stock intake and TB will get you to 600 without problems. Look into a speed density operating system or a gen4 MAF upgrade so you can read the air required for 600hp. Gen3 mafs are done about 4-450hp
Old Jan 5, 2019 | 12:20 PM
Jseal52's Avatar
Ok thank you i will look into those upgrades.
Old Jan 5, 2019 | 05:30 PM
FFDP's Avatar
Speed density all the way if this is a 99-07 classic era truck.
As said stock throttle body and intake will make stupid power.
What year engine did you get? You may get lucky if it's 2004+ because those have better rods from the factory in most cases.
Old Jan 5, 2019 | 05:48 PM
Jseal52's Avatar
The engine is from a 2001. I wasn’t really picky getting it as it was free lol. Still runs good but the body around the engine was toast.
Swerve7rpm2000
Nov 22, 2019 08:32 PM
TurboNgo
Jan 31, 2014 01:59 PM
lglowe
Sep 15, 2012 07:59 PM
Benlugchev
Nov 20, 2011 10:29 PM
mconway68w
Jun 26, 2011 06:47 AM
