lifter retainers
Old Apr 17, 2009 | 10:40 PM
zapata41's Avatar
Default lifter retainers
can you reuse them when doing cam/lifter swap, also is there a difference from the ls1 to the other ls base retainers.
Old Apr 22, 2009 | 11:16 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You can re-use them if there in good shape but there so cheap why not change them... for the LS1 style I think I got all 4 for less then $20 From SDPC. One of our sponsers
They are different for different motors.
#12551162 -Lifter Guide, LS1/LS6 4.8,5.3,6.0 truck engines
#12595365 -Lifter Guide, LS2/LS7
#12571596 -L92 Front Lifter Guide
#12571608 -L92 Rear Lifter Guide
I believe the L92 is also the LS3 style but not 100% on that. Maybe some one else can Clear that up
I do know you can use the LS2 style in th LS1 style engine but not the other way around. The LS2 style is supposedly stronger....
Old Apr 23, 2009 | 06:29 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
x2 just change them...it's not worth it to risk over $20 if one does end up going bad on ya
Old Apr 23, 2009 | 08:05 AM
Tootall's Avatar
yes, reuse them . .
Old Apr 23, 2009 | 08:47 AM
EVILGMC's Avatar
i am going to run LS2 trays in my rebuild.
Old Apr 23, 2009 | 11:26 AM
sickREDsierra's Avatar
i always reuse them... i would upgrade to TI retainers if you are planning on revving to 6500+ though.
i run a dual spring with TI hats now
edit, just re-read the title. LIFTER retainers. i am a moron. the end.
i re-use those too though. did a h/c/lifter swap a few weeks ago and just went back with the same ones.
Old Apr 23, 2009 | 04:32 PM
budhayes3's Avatar
PT's Slowest Truck
You probably don't need to change them, but for the price it's silly not to. If you're not swapping the heads or removing them to get milled, you don't need to change the lifters at all though, unless of course you're having a problem with the lifters.
Old Apr 24, 2009 | 09:32 PM
zapata41's Avatar
thanks for the replys, gonna reuse them as they are in perfect shape. i am doing a h/c/lifter swap.
Tim
OHsixLS3
Nov 22, 2015 07:45 PM
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
Velocity1
Oct 2, 2015 08:01 AM
JoshH
Sep 28, 2015 11:19 AM
