Sleeving a 5.3
Old Apr 24, 2009 | 08:12 PM
Wonderer876's Avatar
Default Sleeving a 5.3
Is it possible? Thought id ask since when you bore the 5.3's out to 5.7 specs most don't have thick, or safe enough walls. And how much could you go if you did sleeve it? Just a curiosity question
Old Apr 24, 2009 | 09:07 PM
L7 Sierra's Avatar
Sleeving is an expensive propisition to just get to roughly a 4 inchy bore. A used 6.0 complete can be had for about $1500 "normally", and that is everything you need to make it run.
So why waste $600 or so to just get a motor to get to that level when it also has a tendency to weaken the block slightly. Also you can get a 6.2 block quite cheap I heard about $900, and that has a 4.030 inch bore.
Old Apr 24, 2009 | 09:09 PM
Yea, just a thinking idea lol appreciate it
Old Apr 25, 2009 | 12:40 AM
53bowtie's Avatar
if you are just boring it to ls1 piston size (3.898 or 3.905) then you should be fine without having to put sleeves in. I have read in multiple threads and websites that the 5.3/4.8 block were designed to be able to bore to 5.7 size safely so you basically have an iron block ls1.
Old Apr 25, 2009 | 12:53 AM
silver-mod-o's Avatar
Hunt&Fisherator
my forged 347 (3.907 bore) started life as a 5.3L, and I plan on putting quite a bit of boost to it, and not think twice about it.... as long as everything is done properly, there shouldnt be any issues.... mines a forged rotating assembly with head studs etc...
Old Apr 25, 2009 | 02:43 AM
Yea if i do that then i plan on running a 2 stage progressive n20 shot on it, thats why i was curious to the strength. 150 outta the hole and another 150 at the 1/8. Or something of that nature
TAPyvehc93
Dec 27, 2015 12:14 PM
pewter00
Sep 14, 2015 09:17 PM
sTNT971
Sep 11, 2015 02:38 AM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
