Largest stock idle cam in a 6.0?
Old Jan 28, 2007 | 11:51 PM
TurboGibbs's Avatar
Question Largest stock idle cam in a 6.0?
I'm helping a friend put together a good 6.0 combo and he's wanting the biggest cam possible and still retain a stock or near stock idle. What size cams do some of you guys have that fits this description? I'm thinking something in the range of low 220's and 114 lsa or 225 and 116+ lsa. It will be a N/A engine.
Also, if you idle yours up to 900 will it smooth out?
My 223/218 114 turbo cam sounds stock at 900 rpms.
What chu guys think?
You guys with 5.3's throw in as well, it would make for a good comparison.
Old Jan 28, 2007 | 11:54 PM
dirt track racer 81's Avatar
look into some of lingenfelters cams..they got some pretty decent sized cams on a very high LSA
Old Jan 29, 2007 | 12:04 AM
moregrip's Avatar
what a rush!
XER lobed 220/224 on a 115 or 116
Old Jan 29, 2007 | 12:11 AM
Steve Bryant's Avatar
LS1 Tech Veteran
I'd look at the GT2-3 from Lingenfelter and the 2002 version of the LS6 cam. They are pretty similar cams really. As mentioned, the have a wide LSA and therefore not so much overlap. Overlap is really what takes away the smooth idle. Wider overlap takes away the intensity/peakness of the power band and spreads the RPM range. It's not a bad compromise, but your peak HP and Torque won't be as great.
Steve
Old Jan 29, 2007 | 12:15 AM
TurboGibbs's Avatar
Thanks guys. I'm aware of the theory behind it, just wanting some real world experiences. Thanks, and keep em coming.
Old Jan 29, 2007 | 12:20 AM
moregrip's Avatar
what a rush!
that's what I gave you , contact mattrem for his thoughts as he's running it on a 115; seemed to like it quite a bit
Old Jan 29, 2007 | 05:31 AM
TurboGibbs's Avatar
Thanks. I sent him a PM but he hasn't been on since 12/26/06
Old Jan 29, 2007 | 08:20 AM
Quik's Avatar
5 year bitches!
iput a trex in a 6.0 and it idles around 825..no where near stock
to get a quiet idle you would have to have a higher lsa i would think
Old Jan 29, 2007 | 12:16 PM
zippy's Avatar
About the biggest I've seen work is the Comp Cams XER273HR. At around 800rpm idle you have to really pay attention to the idle to even notice that it has a bigger than stock cam in it.
Old Jan 29, 2007 | 01:56 PM
moregrip's Avatar
what a rush!
whats the spec on that cam for those of us at work
