Importance of quench on a turbo engine?
Old Jul 12, 2008 | 04:46 AM
stock48's Avatar
9 Second Truck Club
Default Importance of quench on a turbo engine?
I know there are mixed opinions on this, just wanting to know what you guys have experienced. Im going to be lowering the compression on my new engine. I think the quench is a big deal on NA, but the piston manufactures say with FI the quench is of very little, or no importance. I had designed the engine to be run hear at 7000' elevation, but I might be moving back to Ca so the 10.3:1 CR isn't going to work. I talked with a piston guy today who suggested dropping the piston in the hole by switching from a 6.125'' rod to a 6.100'' then adding thicker head gaskets to get my new targeted 9.2:1 CR. I don't know If I like that idea at all. To me once boosted a gain, or mistake in NA configuration is doubled. We were going to cut a dish in the piston but It will get to thin with the 15cc dish I will need. I would change the pistons but no one makes a dished piston that I like.
Old Jul 12, 2008 | 06:03 AM
AdioSS's Avatar
12 Second Club
I asked this question on Speedtalk a while back... http://speedtalk.com/forum/viewtopic...ghlight=quench
Old Jul 13, 2008 | 01:31 AM
stock48's Avatar
9 Second Truck Club
No body? Come on Rick I want to hear your opinion.
Old Jul 13, 2008 | 03:35 AM
Derek @ EDO's Avatar
FormerVendor
Wisecos -11cc piston with stock MLS gaskets and 6.125 rods will put you at 9.2:1 with a 72cc heads.
Old Jul 13, 2008 | 04:44 AM
stock48's Avatar
9 Second Truck Club
My heads are 69cc for some reason. They have been milled 3x for a total of .015''. I like the wiseco but it's a little too heavy, and It has 1/16 rings, I want to stay at stock weight and 1.5mm ring pack. Also looking for a 4032 Alloy. All the pistons I find are the 2618. Mahle can make the piston I need but they are $200.00 each, and takes 12 weeks Im probably going to put together another stocker for now, I bought a set of 05 LQ4 pistons with the LS 2 style rods from Kyle. Im just going to dingle ball a std bore 6.0 block I have out in the garage and run it with my old beat up ****. So we might see just how far a stock internal 05 up 6.0L will go. Im going to hold off on the new engine for now, I don't even want to build it unless it's exactaly the way I want it.
Choda
Jan 22, 2026 02:03 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
lxcoupe
Jul 27, 2015 08:19 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
Mzay
Jul 6, 2015 11:03 PM
