LS balancer installation tool?
Old Jul 12, 2008 | 08:12 PM
Raffman's Avatar
Default LS balancer installation tool?
What bal install tool is everyone using? I've got a blue point kit that won't work. Also I assume these are zero balance since there is no keyway....anyone?
Old Jul 12, 2008 | 08:37 PM
KySilverado's Avatar
Longer bolt with a big washer is what I use. Get it on far enough to finish up with the stock bolt.
Old Jul 12, 2008 | 08:43 PM
phasemaster1's Avatar
Make sure you get the longer bolt to get it started, if you try and use the regular replacement bolt its to short and you can strip the the threads in the crank snout.
Old Jul 12, 2008 | 10:19 PM
InchUp's Avatar
what they said, plus get a new bolt after you have the balancer on.
Old Jul 13, 2008 | 08:45 AM
budhayes3's Avatar
PT's Slowest Truck
Correct, there is no balance to the crank pulley. I bought an installation tool from the tool section on LS1Tech a few years ago. The one I have is basically a piece of threaded rod and a nut. I noticed a different one there last week, looks pretty nice
https://ls1tech.com/forums/showthread.php?t=391883
Old Jul 13, 2008 | 09:31 AM
Raffman's Avatar
Thanks for the input guys. Think I'm going to make one, some hardened all thread 16mmx2.00 and a spacer, thrust washer and a little tig time ought to do it...
Three6GMC
Nov 5, 2015 10:02 PM
Tig
Sep 30, 2015 07:39 PM
bgray
Jul 23, 2015 10:56 AM
