I need 800 hp but clueless where to start..
Old Feb 17, 2013 | 10:30 AM
btrinanes's Avatar
Registered User
Default I need 800 hp but clueless where to start..
Hello guys I have an 09 suburban with a Lyshom, kooks longtubes and hi flow cats with Corsa cat back. It makes about 500hp but I'd like to step it up. I'll probably switch to a turbo but was curious what are the supporting mods needed to do this sucessfully. Ive searched and the obvious stuff pops up but I'm still not clear. uprgrades to the engine, fuel system, tranny and rear end seem to be the obvious but Im a ford guy and I dont know where to even start or to contact for help. Thanks for the help..
Old Feb 17, 2013 | 10:34 AM
Atomic's Avatar
I have a gauge for that
Well 800hp is pretty useless unless you like doing 70mph rolls or have a badass suspension setup, otherwise its just a burnout queen. If you want to keep the blower you could add some nitrous on top, or switch to something like an 88mm turbo.
Old Feb 17, 2013 | 10:51 AM
btrinanes's Avatar
Registered User
I def will probaby switch to turbo since I'd like to use a boost controller to aid in traction. I have a lot of turbo parts lying around Including a few 88mm turbos. I have built a lot of Fords but this is my first Chevy so im lost when it comes to shops, tuners, builders etc. to help me w this project.
Old Feb 17, 2013 | 04:55 PM
sand man's Avatar
what motor do you have ? 5.3 ?
is it the 1900 or 2300 supercharger ??
Old Feb 17, 2013 | 05:30 PM
btrinanes's Avatar
Registered User
It's 5.3l but I'm not sure what size the blower is. I bought right when vortech came out with it so maybe it's the small one??
Old Feb 17, 2013 | 06:21 PM
sand man's Avatar
did you swap to a none DOD lifters?
you seem to run your stock camshaft
Old Feb 17, 2013 | 06:32 PM
btrinanes's Avatar
Registered User
no i have not but i was planning on buying a junkyard 5.3 and rebuilding that w/ rods, pistons, cam, lifters and heads.. my current engine is stock but runs perfect w 100k but i figured id leave it in because its my dd.. Cam I just get a pre 07 5.3 that doesnt have DOD?
Old Feb 18, 2013 | 01:20 PM
sand man's Avatar
get an LY6 while your at it , better than a 5.3 , no DOD to begin with and you can swap the cam only and have those great L92 heads and go 800 flywheel easy with 9.7 lower CR
Old Feb 18, 2013 | 05:57 PM
btrinanes's Avatar
Registered User
Thanks! That's what I was hoping. Pretty sure the local junkyards won't know know what a LY6 is, what model/years trucks did that motor come in??
Old Feb 18, 2013 | 06:59 PM
62nalide's Avatar
Well a 5.3L with a good turbo setup will net you 800hp easy thing is lets hope the trans likes it
