I bought 2 cams...which one should I run?
Old Sep 12, 2014 | 02:28 PM
jasonst's Avatar
Default I bought 2 cams...which one should I run?
99 5.3L
Fast 78 w/ Shaner S3 ported TB
Stock 852 heads with mild porting
Mac mid length headers with 2.5 dual exhaust and no cats.
This is in a 2750lb Rx-7 with 4:10lsd, a built 2004r with a 3200 stall.
Futral F11 228 230, 576 595, 114: I originally bought this cam and I hear its pretty sweet and has a subtle idle but I want more chop. I found a Comp Cam 230 234, 608 598, 111 but I'm not sure if it's "too big".
My Rx-7 is an occasional cruiser, not a purpose built car...just want to enjoy driving it around.
I'd like to mill the heads and get my compression up. I run 93 octane. Is 11.1 achievable by simply milling the heads and using thinner head gaskets?
I appreciate the help,
-Jason
Old Sep 12, 2014 | 02:44 PM
oakley6575's Avatar
I'd run the first one. You will still get a good chop with that cam and it better suits your conveter
Old Sep 12, 2014 | 02:51 PM
BlackGMC's Avatar
Resident Retard
I would run the second one with vehicle that lite, 4.10s and i assume your running a 26ish tall tire it should scream!
Old Sep 12, 2014 | 03:22 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I think you could get away with the bigger cam in that car. Should run pretty hard, esp with a bump in compression.
Old Sep 12, 2014 | 03:37 PM
jasonst's Avatar
Thanks guys. I'm attracted to that 111LSA!
Can I get away with milling these heads .030?
-Jason
Old Sep 14, 2014 | 07:49 PM
jasonst's Avatar
Anyone else?
Thanks,
-Jason
Old Sep 15, 2014 | 09:35 AM
Chiphead's Avatar
11:1 is a tall order with stock 5.3 dished pistons. Using a gasket thinner than .040 risks running the piston into a chamber b/c the stock slugs stick .008" or so above deck. I've read here that cutting the heads more than .030" is where you start to have intake fitment issues.
You can always have the tuner dial in some idle chop.
Old Sep 15, 2014 | 10:12 AM
jasonst's Avatar
Alright, so the Comp Cam 230 234, 608 598, 111 with .030 milled off the heads and .040 HG should be a safe bet.
-Jason
Old Sep 15, 2014 | 11:46 AM
tim wellington's Avatar
Default Cam choice
I like 2nd one comp cam .only problem i see is that 200r4 holding up .shoot some pictures of car .that my next project a rx-7
Old Sep 17, 2014 | 03:53 PM
jasonst's Avatar
The transmission is the CK Performance Street/Strip build. Should be fine (famous last words).
stealthperf
34
Feb 14, 2016 11:35 AM
iregret
Jul 27, 2015 10:31 PM
04450r
Jul 24, 2015 01:58 AM
08nali
Jul 23, 2015 11:39 PM
