how much can a LQ4 take?
Old Jun 21, 2008 | 10:46 PM
sowaidi's Avatar
Default how much can a LQ4 take?
could an LQ4 take around 800 hp with some mods and of course a turbo? im tryin to make my mind on something and deifnately need some advice.
Old Jun 21, 2008 | 10:59 PM
00Silv4.8's Avatar
I kinda doubt it. Thunder550 has a 408 with a turbo and I think hes making like high 500 on like 14 lbs of boost?? Someone correct me if Im wrong
Old Jun 21, 2008 | 11:09 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
If your going to build the internals it can hold up to anything but for a stock block it could handle up to 10 PSI boost with ARP rod bolts and other stuff like a meth controler I'd say something around the 500HP+. It all really depends on what your plans are.
You should do some research about it and I am sure you'll find alot of info.
Old Jun 21, 2008 | 11:30 PM
99Silverado5.3's Avatar
Look up stock48..he's has a slick setup with some big #'s.
Old Jun 22, 2008 | 12:10 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Stock48's engine is in a thousand pieces...
A lot of guys are making 600+RWHP on stock bottom-ends with reliability. A few guys have pushed it and made more on occasion.
Old Jun 22, 2008 | 12:14 AM
00Silv4.8's Avatar
hah, I stand corrected. Thanks fellas. The search button is ur friend. Scour that ****. If u still have a question post up, but be pretty specific
Old Jun 22, 2008 | 02:27 AM
stock48's Avatar
9 Second Truck Club
I have seen some big HP claims but not to many time slips. It might last for a while making 800hp on a dyno, or spinning the tires on the street. But run some true mid 10 sec passes in a 4900lb 4x4 truck, and beat on it daily for 6mos it will let go. Just depends on the tune, and what you are going to do with it. The rods are the week link. I would trust a stock 6.0L with studds to last awhile at ~600RWHP. Start getting up around 700 and your on borrowed time if you run it hard.
Old Jun 22, 2008 | 01:28 PM
sowaidi's Avatar
thanks for the help guys. Stock48..how much power do you have?
Old Jun 22, 2008 | 02:54 PM
stock48's Avatar
9 Second Truck Club
Didn't dyno it after I got it running right. Went a little over 700 corrected with a conservative tune, no meth before I ported the heads. Truck has been 10.59@5000' Da with the engine on it's way out, is 4x4 and 4900lbs. Dyno's will always vary, and are really should just be used as a tuning tool. I would say it is better to use track times to evaluate power. Also a lighter truck will be a bit easier on the engine. I think JJ has a stock 6.0 in a Rc, 2wd truck running high 10's, near sea level and it is still alive.
Old Jun 22, 2008 | 04:55 PM
Wheatley's Avatar
Truck Sponsor
Sowaidi,will you pm me your number buddy?
calsdad
Jun 14, 2023 11:07 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
lxcoupe
Sep 29, 2015 09:20 PM
Slammed silverado
Sep 28, 2015 06:14 PM
zraffz
Sep 8, 2015 07:40 PM
