how far to bore?
Old Mar 12, 2006 | 10:04 AM
fullthrottledan's Avatar
Default how far to bore?
On a 5.3, can you take it to a 4.030 bore? Not sure if .052 would be too safe to take off.
Old Mar 12, 2006 | 11:08 AM
TravisH's Avatar
the 4.8/5.3 block has a bore of 3.779? and you can bore it to make it a 5.7 which is to 3.893?.
Old Mar 20, 2006 | 02:33 PM
01Blackerado's Avatar
Actually even though that's very close, you're still a little bit off!! The 4.8/5.3 block can be bored safely to 3.903 to obtain a 383/6.2 with a 4" crank!!!
Old Mar 20, 2006 | 05:43 PM
TravisH's Avatar
I was just giving the specs on making the 5.3 into 5.7....I thought that was all you could take the 4.8/5.3...
Old Mar 21, 2006 | 06:15 AM
370 cubes is all i want out of it. I have a 6.0 block bored out in the truck in the sig, but i have another 2003 gmc with a 5.3 thats my daily driver and needs some more motor, but didnt want to get too expensive with it.
Old Mar 22, 2006 | 04:23 AM
What rods do you need to work with the 4" stroke?
Old Mar 22, 2006 | 09:08 AM
6.125 length rod's....4" stroke crank....3.903 bore pistons...makes 383CI
Old Mar 22, 2006 | 02:32 PM
thanks
Old Mar 22, 2006 | 03:01 PM
On20Z's Avatar
Whta hp gains can be expected with a 383 build with 243 workd heads and a Z06 cam.I have thought about this myself.
Old Mar 23, 2006 | 11:34 AM
Depends on the tune, compression ratio, flow numbers on heads, any mods done (ie: exhaust, tb, etc...), and the drivetrain!! But really anywhere from 360+hp to about 460ish with that cam!! Bone stock mods, all motor with Z06 cam, with about 9.5:1 comp ratio should have you a little over 400hp out the motor....not wheel hp!!!
lukn4trbl355
Oct 21, 2015 11:19 PM
Wolftrk99
Oct 2, 2015 08:17 AM
01silvy
Sep 26, 2015 10:20 PM
dantheman1540
Sep 15, 2015 08:28 PM
Alco
Jul 25, 2015 01:47 PM
