High volume or high pressure oil pump
I'm rebuilding my 5Three. I currently have milled 862, 550 ls1 hot cam, mild ported TB, CAI, and I'm getting a mail in tune from frost, and I just recently bought an ls6 oil pump but found a deal on a brand new melling high volume oil pump. Before I buy it should I keep the ls6 or the high volume but not sure it buying the high volume would be a waste if I really need the high pressure
Stock pump, sorry, seen to many GOOD aftermarket pumps **** a engine out. Just my OP, but sure alot of others will agree. Unless your running over size pans and high RPMS for extended periods, a high flow pump is not needed. The stock pump works well.
The stock oil pump on my L76 produced pressure about 10psi over stock. Not sure what GM considers that pump, but it was definitely higher than what I normally see on truck engines.
Ferocity02
Jul 17, 2015 07:05 PM
