Help me with my 370 build.
Old Mar 29, 2008 | 06:28 PM
  #41
gao8302's Avatar
Do you think head studs are needed? I just always thought that a person should put head studs in with FI. I just dont want to have a weak link on the motor.
Old Mar 29, 2008 | 06:33 PM
  #42
gao8302's Avatar
I plan on running the radix with a shot of N20. So i dont know what kind of hp number i will be putting down.
Old Mar 29, 2008 | 06:35 PM
  #43
Derek @ EDO's Avatar
FormerVendor
Its a matter of opinion, how much power do you plan on making?
If its under 700RWHP then i think the bolts will do just fine.
Old Mar 29, 2008 | 06:38 PM
  #44
gao8302's Avatar
I will hope for the most but i really have no idea what this set up will put down.
Old Mar 29, 2008 | 06:50 PM
  #45
FormerVendor
Radix 112?
Old Mar 29, 2008 | 06:55 PM
  #46
InchUp's Avatar
My grandfather always used to say "A head bolt is a decision made with your wallet. A head stud is an engineer's decision." Wouldn't you just kick yourself if something went wrong during a 1/4 mile pass/weekend night of cruising around town where a stud would have prevented the problem?
Old Mar 29, 2008 | 07:02 PM
  #47
gao8302's Avatar
Yeah. Im going with studs for that reason.
Old Mar 29, 2008 | 07:03 PM
  #48
gao8302's Avatar
I will get a 122 now that im going all out with this build.
Old Mar 29, 2008 | 07:07 PM
  #49
FormerVendor
LOL, stud or bolt, if you experience detonation you can blow a gasket.
If he uses studs and has problems whats he going to say?
Should have went with bolts, now i got to pull the damn engine to take off the head!
If your using the 112 blower i dont think that thing has enough breath to hit 700RWHP.
Theres always an upgrade available.
Thicker heads, stronger rods, coated pistons, coated bearings, billet caps, lighter crank.......
Pick what you need! How much do you want to spend?
Old Mar 29, 2008 | 07:18 PM
  #50
gao8302's Avatar
I will get the 122 and be done with it. But this year i will just be running nitrous but not sure of the shot. I have never ran nitrous before so i dont know how big of a shot to run. Im thinking 150.
