Help me with my 370 build.
Old Feb 3, 2008 | 08:49 PM
gao8302's Avatar
Default Help me with my 370 build.
Im picking up my motor this this weekend. A LQ4 with 317. I would like to figure out what way i want to go with this motor. I stuck between going with either a supercharger/turbo or on the other hand N2O. I want a 11sec truck if possible. Im going to use the factory 317s and stick with the factory crank. Everything else on the motor will be forged. As far as cam go im think about staying with the cam i have now but im willing to change it if i have to. I guess what im asking is how should i set the motor up cr wise and what power adder should i go with. I know everyone is going to say the 122 radix but will a 112 take care of the 370 and to what point? Im selling the whipple so thats out of the question. Also since there is a few 370 build going on what is everyones prefernce on pistons and rods so far. Any better than other? Thanks guys.
Old Feb 3, 2008 | 08:53 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Whether or not to SC or Turbo is one big question. I dont think anyone would disagree that the MP112 is too small for a 370.
Old Feb 3, 2008 | 08:58 PM
gao8302's Avatar
I have done alot of reading but i got mixed responses to if the 112 would feed a 370. How hard could i push the 112 before being out of the range of the blower?
Old Feb 3, 2008 | 09:02 PM
trever1t's Avatar
Call Magnuson or PM https://www.performancetrucks.net/fo...p?userid=44662 they will get you hooked up with the right kit for your application.
Old Feb 3, 2008 | 09:11 PM
gao8302's Avatar
Also am i going to be killing my combo with the 317s? Should i do anything with them or do i have to do anything to them for the build?
Old Feb 3, 2008 | 09:12 PM
Derek @ EDO's Avatar
FormerVendor
Go with an off the shelf diamond piston and some Callies rods.
Old Feb 3, 2008 | 09:14 PM
gao8302's Avatar
what cc piston for a FI setup?
FormerVendor
If all you want is 11's id say leave them stock with the exception of springs. If you are going to invest cash in heads at least get some after market castings with a thicker deck IMO.
If you want to stay with the same casting but have a worked set contact Richard@ WCCH
Old Feb 3, 2008 | 09:18 PM
gao8302's Avatar
I will most likely leave them stock.
Old Feb 3, 2008 | 09:19 PM
FormerVendor
Id say try to get 8.9:1CR
You may have to get some cosmetic .40's and go with a -15 cc piston. Diamond select (total seal) rings will work fine.
I would contact Rick@synergy for a cam for the motor. He will spec something out that will get you awesome HP/TQ
