Has anyone ran 823 heads on there LQ9
I was looking for a set of 243s when I found these 823s cheap. I was told they were better than the 243s but I don't know anything about them. So any opinions or info or experience with them would be great.
I was wanting to swap them onto my 04 HD with a cam swap. Will the L92 / 6.2 intake be a direct replacement ? I was told my stock intake would work ,but I want to make sure before tearing anything down.
Nice thing about the 823's too is a 2cc smaller chamber so should raise your compression like .15-.23 not a bad little side affect. One thing to think about too with an aftermarket cam, a huge intake valve, and flatops is PTV clearence. Not sure what type of releifs LQ9's have. Also when you order a cam make sure you tell them that you have L92 heads as they will give you a cam that is spec'ed out differently than for a cathedral port head. They may also shed some light on any PTV issues that may arise.
I have a set of L92/LS3 heads on my LQ9. I love them, although I had Lingenfelter CNC them for me.
LQ9s have true flat tops with no reliefs. I had mine milled .030 and had very little PTV with my aftermarket cam. ALWAYS check PTV whenever you change cams, or goto a head with a HUGE valve like this one.
PTV depend son your camshafts valve events. the exhaust vavle thing your talking aobut most likely stems from a thread showing why an L92 heads wont work on a 3.900 bore. The pic showed the exhaust vavle hitting the cylinder wall.
I had some PTV issues and had to change cams. Although I seem to be one of the few with PTV issues. Others have had CNC jobs and milled, yet could fit bigger cams. I couldnt.
I tried a Comp LSR 223/231 and had .045"-.050" on the intake. I backed out to the 219 and had around .075".
The large exhaust duration is because its an L92 specific camshaft. Comp has cathedral port cams and L92/LS3 port cams. My cam but for cathedral ports would be a 219/227 instead.
Once you get those LS3 heads ported and get the intake and exhaust flow rates more balanced like cathedral heads, I dont see why a huge exhaust duration is needed. It seems that a more traditional cam would work well.
I've got an Lq9 with ported 317s and a 222/226 cam, it pulls well, but it's hardly enough. I'm wanting to switch to the LS3 heads, the issue is I want a big cam. My current cam is way too tame, just like stock basically, drives like stock. I want something in the 230s duration, but how/if that can even work with flat top LQ9 pistons I do no know.
