Guys please help My truck is driving me nuts !
Old Apr 20, 2013 | 06:04 PM
jrplz's Avatar
Question Guys please help My truck is driving me nuts !
making ticking noise and a slight miss idle. I have checked
Fuel pressure
new spark plugs and wires
clean out maf sensor
clean throttle body
Im going to check the push rods , I heard that its common for bent push-rods on 5.3
2003 z71 tahoe 5.3 120,000.00 Miles
Anyone know of a good set of push rods (aftermarket) going to replace them for the heck of it .
truck only mods are
Nelsons tune (mail)
EFans
thanks guys
Jr
Old Apr 20, 2013 | 10:16 PM
lycominghunter's Avatar
I just bought comp 3/8 hardened pushrods. stop pushrods are 5/16 in diameter from my research, but I got the hardened, larger pushrods since im doing a turbo build.
I don't know about the ticking noise. Is it occurring only while idling? Can you hear it when you're driving? Are all of the spark plugs firing correctly? I guess you got new wires and plugs so they should be good, but maybe a bad coil pack?
Old Apr 20, 2013 | 10:32 PM
06murder's Avatar
Ls motors have a slight. Tick to them.
Old Apr 20, 2013 | 10:33 PM
06murder's Avatar
Comp cam have chromoly p/r there bout 100-160
Old Apr 26, 2013 | 02:27 PM
jrplz's Avatar
thanks guys for the advice will order the pushrods and fill you in ones I get her done !
Old Apr 27, 2013 | 02:40 PM
Camin00's Avatar
is it tapping or ticking?
Oil could be a lil low not allowing enough pump pressure to lubricate the top end.
If my truck is 1/2 way up the dip stick tap tap tap tap but once I fill it up slightly past the operating range no tap.
Old Apr 30, 2013 | 09:31 PM
gnd111's Avatar
Carbon build up piston slap from those years
Old May 8, 2013 | 12:36 AM
D1SCSS's Avatar
It could be a lifter going bad causing the noise and slight misfire.
pjb1972
Sep 17, 2015 02:06 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
ALynch
Jul 6, 2015 09:49 AM
