ford mustang injectors !!!! on my 5.3 silverado
Old Sep 1, 2008 | 12:32 PM
corvette_uae1's Avatar
Default ford mustang injectors !!!! on my 5.3 silverado
would the ford mustang injectors will fit my 2007 silverado !!! 5.3 engine ???
42lbs cuz i want them direct fit .
i already tried to order the delphi injectors from many suppliers???
racetronix no more stock left??!!!
thunderracing also
on ebay i tried also !!!
so i thought why not to buy the ford mustang injectors if they are direct fit on my 5.3 engine .
Old Sep 1, 2008 | 12:35 PM
7845's Avatar
Banned
they are direct fit for the car intakes. not to mention the injectors are rated higher then they are for fords. so your sv0 42 is more like a 49lb injector.
Old Sep 1, 2008 | 12:36 PM
kbracing96's Avatar
No, they are 5/8 taller and need a different pig tail. On the bright side, they actually flow about 49lbs/hr at our 58psi of fuel pressure.
Did you try Nelson Performance for the 8.1 marine injectors (direct replacement 43lbs/hr)? ----->
Old Sep 1, 2008 | 12:59 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Either that or look for Mutec "shorty" 42s which will also be a direct fit.
Old Sep 1, 2008 | 02:11 PM
zippy's Avatar
Is your truck a flex fuel or not?
Old Sep 1, 2008 | 02:31 PM
kbracing96's Avatar
These are what your looking for, $250...
https://www.performancetrucks.net/fo...d.php?t=423907
Old Sep 4, 2008 | 12:11 AM
PappyDan's Avatar
Tribe Shaman
why yes they do flow like that, i have a set on mine.
Old Sep 4, 2008 | 05:44 AM
TXsilverado's Avatar
gotta have a car intake manifold/fuel rail. im running the SVO red tops on my motor.
Old Sep 4, 2008 | 11:22 AM
SRT10KLLR's Avatar
Former Vendor
Or you can get 60lb Multech injectors that are direct Plug n' Play for our trucks just like the 8.1 Marine injectors.
Old Sep 4, 2008 | 11:32 AM
zippy's Avatar
I still didn't see if he has a flex fuel truck. Over 50% of the 07' 5.3L's we sold were flex fuel and use a different injector/connector. This is kind of important to know. I believe they make injectors up to something like a 79lb hr that is a plug and play for them.
