Engine Girdle....
Old Dec 6, 2005 | 01:38 PM
Yellowsierra's Avatar
Default Engine Girdle....
I was wondering if anybody has used a engine girdle for there LS based motor? Im thinking about getting one sence I have an alum. LS1 block. Here is the website..... http://www.dmperformance.org/
Old Dec 6, 2005 | 01:42 PM
Fogle07's Avatar
for the money i dont see why somebody wouldnt do that to their 5k motor
Old Dec 6, 2005 | 02:18 PM
Thats what im thinkin
Old Dec 6, 2005 | 03:07 PM
vanillagorilla's Avatar
I dont know if its totally necessary with Gen 3 engines being 6 bolt mains and all. If it helps you sleep at night, then go for it. I have one on my Gen 1 small block, but it sure as hell isn't a 6 bolt main.
Oh yeah, it looks like it could double as a nice crank scraper too! An added benefit for you high rpm guys.
Old Dec 6, 2005 | 03:27 PM
I dont think I will get it but though I would bring it up to see what everbody though. I already order all my Arp studs and will have to order them again if I got the girdle.
Old Dec 6, 2005 | 03:35 PM
budhayes3's Avatar
PT's Slowest Truck
Looks like a nice product, especially for high hp aluminum block applications.
Old Dec 6, 2005 | 04:03 PM
I built my bottom end with a Arp stud kit and steel main caps,if that had been around I would probably have bought one.I say go for it.
Old Dec 6, 2005 | 04:46 PM
I may buy it. I just got off the phone with the guy that sells it he said he would sell me the girdle for $350 and the ARP studs are $175. The reason Im considering it is because im working on my second motor. My first motors mains got pulled to the side .006" so if these will help that from happening again its worth the money.
Old Dec 6, 2005 | 05:56 PM
I just talked to Eric@APE and he said its not really needed. Eric said it may work but the mains will need line honed with the Girdel because a girdle will sometimes pull the mains out of line. My blocks mains and the bores have already been honed so its not really worth it to have all that done again.
Old Dec 9, 2005 | 06:17 PM
IDISAPR's Avatar
I was just about to bring that up, not to mention more $$$ for machining the caps, oil pickup extension, problems with exhaust clearance, leaks and definitely need the girdle along with torque plates bolted to the block prior to the hone.
superchomper2003
Aug 26, 2015 09:39 AM
nrmskate
Aug 11, 2015 02:44 PM
DrX
Aug 11, 2015 07:25 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
85SS/85GN
Jul 22, 2015 12:48 PM
