did i get ripped?
Old Nov 28, 2007 | 11:44 PM
map0711's Avatar
Default did i get ripped?
i just installed my new cam, so i wanted to sell my old one, which i thought was a 2002 Ls6 cam. i bought it used from a friend that works at a stelership, so i trusted that he knew what he was selling me, we have also been friends since we were both 5 so again i trusted him. i bought it and installed it without checking it that same day. i have tried measuring lift to make that it is a ls6 cam cuz i don't want to rip someone else off. i've tried to measure it but only get .480 lift, i don't know if i'm measuring wrong. what other way can i tell if it truly tell if it is an ls6 cam.
Old Nov 29, 2007 | 01:34 AM
jakebdb56's Avatar
there should be a p/n etched on the end of the cam right?
also, what way are you mesuring lift?
Old Nov 29, 2007 | 10:48 AM
kbracing96's Avatar
Ya, how are you trying to measure the lift? Lift is measured at the valve AFTER it is increased by the rocker arm ratio since they increase the actual cam lift by 1.7 to 1. So the cam its self will be less then the advertised lift of it.
Old Nov 29, 2007 | 11:34 AM
Tootall's Avatar
if its an 02 and ^ it will have this on the end
Old Nov 29, 2007 | 07:48 PM
map0711's Avatar
Default cam
mine says
0950
s 17
1057
exactly in that order
i was measuring the highest point in the lobe, minus the small side, multipied by the rocker arm ratio
Old Nov 29, 2007 | 10:41 PM
dkota1968's Avatar
If im looking at it right, the top 4 numbers are the last 4 of the part # it self. Looks like you have the 2001 LS6 cam. The specs are 207/217@.050 525/525 on a 116 center line. Still better than a stock one. 2002 is 204/218 550/550 on a 118.5 center line. All according to the GMPP book.
Old Nov 30, 2007 | 12:13 AM
map0711's Avatar
Default cam
well that solves that problem, thanx now to get rid of it
1slwgto
Oct 1, 2015 01:51 PM
MOBBN
Sep 22, 2015 08:07 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
Riceconvert5.3
Jan 20, 2005 07:55 PM
8100hammer
Sep 20, 2004 05:22 PM
