Crank Interchangeability???
Old Dec 30, 2012 | 07:16 AM
  #21
Sticky material right here.
Old Dec 30, 2012 | 09:44 AM
  #22
Beatdown Z's Avatar
Laid Back
You could pick up a truck crank for $100 or less and a complete set of used rods for around $50. I have seen re-manufactured truck cranks in the $150 range if you look around.
By re-manufactured, you mean grinded and polished, right? Can you point me in the direction of any cranks around that price range?
I'm about to buy a used crank off ebay for $90 shipped. I just wasn't sure how much balancing would cost, and then grinding if it needs it. Going to call some machine shops tomorrow...
As for the rods, I was only planning on replacing the one that spun the bearing. The rest of the bearings were in good shape.
Old Apr 21, 2013 | 09:04 AM
  #23
Beatdown Z's Avatar
Laid Back
I dropped a new crank in the aforementioned LS2. Made my own reluctor wheel alignment tool and swapped to a 24X wheel. Worked out good.
Now I'm rebuilding another LS2 and I'm using an LQ4 crank. Had it balanced and metal had to be added to it, jacking up the cost of the balance job quite a bit. But, at least I know it will be a smooth running engine when I'm done with it.
Old May 1, 2013 | 10:42 PM
  #24
TexasGMC08's Avatar
5.8, 5.7, 6.0, 6.2 use the same crankshaft also uses a 58X wheel... the 4.8 is a shorter stroke and uses a 24X wheel.... you can get a aftermarket crank and have the wheel you need installed on.
RustyD
May 23, 2016 07:04 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
trxmxzx
Sep 29, 2015 07:42 AM
Justin87gn
Sep 10, 2015 12:06 PM
