Crank Interchangeability???
I'm redoing the bottom end in an '05 LS2 and it has the rare/hard-to-find 24x crank.
My question is, are there any non-LS2 cranks that would work without having them balanced? In thoery, an LQ9 crank would work, and possibly an LQ4 crank. What do you guys think? |
1 Attachment(s)
All the crank are the same. I have a ls2 crank in my lq9 not problems here
x2 on using a lq4/lq9 crank. There the same.
Actually, i think ls1, ls2, 4.8, 5.3, and 6.0 are all the same. Same stroke i believe, just different bores.
EXCEPT for a early 6.0 crank
They can only be used with a 80e trans |
I thought the 4.8 & 5.3 shared the same bore size/block but the 4.8 crank has a shorter throw.
Originally Posted by 2doorfury
(Post 5044775)
LQ9's have the same piston and rod assembly as LS2's, correct? LQ4's have the weaker rods, dished pistons, and pressed pins, right? |
Its all in the bore, rods and pistons. Other theb that the cranks have the same stroke. Buuut, you are correct about the ls1/ls2 cranks being drilled.
I think lq4 and lq9 rods are the same. I believe under 06 were the good ones. I believe they were forged. Lq4's have dished pistons and pressed pins. Lq9's have the flat top pistons and i believe pressed pins also.
