Checked out the heads today
Old Oct 29, 2010 | 10:15 PM
DrX's Avatar
DrX
Default Checked out the heads today
Well, only the "good" side so far. Here a some pics of the valve seals on the left head, or what's left of them. #7 exhaust valve stem didn't slide out real easy like the others either.
Original carnage thread https://www.performancetrucks.net/fo...d.php?t=470198
#1 exhaust
#1 exhaust
#3 intake
#1,3,5 intake- scratches on #1 are from pulling it off. The others were already off or loose
#1.3.5 intake
Old Oct 29, 2010 | 10:30 PM
skeet's Avatar
dayum!! that sux, deffinitely some major surgery needed!!
Old Oct 29, 2010 | 10:37 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Whos heads?
Old Oct 29, 2010 | 10:53 PM
DrX's Avatar
DrX
Whos heads?
ETP LS7 style LSX heads.
Old Oct 29, 2010 | 11:30 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
How much valve lift in your setup? And which valve springs are those?
Old Oct 29, 2010 | 11:42 PM
1slow01Z71's Avatar
You going to send them to MAST now to see what the root cause is?
Old Oct 30, 2010 | 12:07 AM
DrX's Avatar
DrX
Engine specs:
Old Oct 30, 2010 | 12:28 AM
Hmmm, well I see that the heads came assembled to you. Not much info on which valve springs those really are. That cam & rocker combo puts you at .630 and .635 lift, on small combustion chambers. To me, it looks like the valve springs were not up to the task.
Old Oct 30, 2010 | 01:21 AM
DrX's Avatar
DrX
Apparently, the heads were shipped to the engine builder with the valves and springs assembled. Spring description is only "upgraded dual springs"
Old Oct 30, 2010 | 07:41 AM
budhayes3's Avatar
PT's Slowest Truck
Are those the correct seals for that application? What do the valve guides look like?
