Can a 5.3 L33 Alum. block be bored out...
Old May 25, 2007 | 11:10 AM
Stampede4ever's Avatar
Default Can a 5.3 L33 Alum. block be bored out...
to a 5.7?
Thanks.
Old May 25, 2007 | 11:12 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Nobody on here has ever tried AFAIK, but I'd like to know how feasable it is also.
Old May 25, 2007 | 11:30 AM
mwalls54's Avatar
Need More N2O Mod
I would think it could be done by a good machine shop. just make sure they dont mess up the sleeves.
Keith's Avatar
I read somewhere on tech that the L33 has the same size aluminum casting as the 5.7L, but with thicker iron sleeves to bring it down to the 5.3L bore. I think it was in the conversions/hybrids section.
Old May 25, 2007 | 11:31 AM
nighthawk08's Avatar
how thick are the iron sleeves in the blocks I wonder?
Old May 25, 2007 | 12:16 PM
trever1t's Avatar
Cost wise it'd probably cost the same-or less to just buy an LS6 block and do it that way, huh?
Old May 25, 2007 | 12:58 PM
PappyDan's Avatar
Tribe Shaman
if i remember right, all 4.8 / 5.3 blocks were designed by gm
To be punched out to a LS1 5.7 bore.
This included the aluminum 5.3 blocks too.
Old Jun 15, 2007 | 09:10 PM
ChevyThunder17's Avatar
I know of a gentleman that works for GM, name withheld. He shared with me that the 5.3 iron can in fact be bored out to be a 5.7. The original design was an iron 5.7 to be used in the B-body platform (RWD Caprice) and the aluminum for the F & Y-body.
They then decided to kill off the B-body and make the iron block to a 5.3. They never redesigned the sleeves, which is why you can bore it out so much.
The 5.3 aluminum should be the same deal (take a pic of the block if you can), but I would imagine that it would be easier just to get an LS1 block.
Raggedz71
Jul 29, 2016 10:20 AM
Jake75
Aug 5, 2015 01:26 PM
jaypowe11520
Jul 29, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
4B11T
Jul 13, 2015 03:48 PM
