Cam recomended for LQ9 w/ ls3 heads
Old Apr 30, 2008 | 10:32 AM
Z28RPM's Avatar
11 Second Club
Default Cam recomended for LQ9 w/ ls3 heads
I am needing some input on witch cam would perform the best. I am shooting for 500 + HP. It will have a stock bottom end. I am going to add LS3/L92 heads with patriot gold springs. Comp 7.400 push rods. Ceramic CTS-V high rev racing Roller lifters. L92 intake with factory 90mm throttle body and 33 lbs. injectors. It already has a RPM level 5 with a Precision 3200 milti-disc converter. It rocks with the stock motor, but like everyone else.. IT NEEDS MORE POWER!!!!!
Old Apr 30, 2008 | 10:01 PM
PappyDan's Avatar
Tribe Shaman
a tr 224 would be nice
Old Apr 30, 2008 | 10:18 PM
InchUp's Avatar
I have a brand new custom grind CompCAMS camshaft for sale if you need a 224 style cam. It's a 224/228 with .581/.588 on a 114 LSA, 113 intake center line. Customer backed out of the build after the camshaft was already made so now it just has to go. PM me if you're interested.
Here's the cam card printed off the computer that signaled the guys at CompCAMS to get to work.
Old Apr 30, 2008 | 11:03 PM
7845's Avatar
Banned
you should use a cam designed for those heads. which a few companys are startign to produce. i think GM has 3 stages of ls3 cams to chose from
Old May 1, 2008 | 10:15 AM
OnyxSilveradoSS's Avatar
get a custom grind. I found very little info, and calling comp is a crap shoot. three calls, three different cams.
I have a post about custom cams and listed a few choices. good luck.
Old May 4, 2008 | 06:33 PM
xdanny510x's Avatar
im using a 230/244/114lsa in my ls3/l92 stroker
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
06 4.8
Jul 15, 2015 07:17 PM
Aboss
Jul 9, 2015 10:28 AM
