cam question
i found a cam on ebay im bidding on. the specs are 500/500 lift and the dur. is 209/198. thats all i know about the cam. how do yall think it will do in my truck untill i can afford to buy a bigger cam with springs, lifters, push rods and all???
Sounds like a LS1 cam. I have one I would let you have for cheap, but I cant get to it right now. I put it in my truck, and the powerband was a little higher but it ran good, very similar to my 206/212.
Originally Posted by 912jonathon
ok if i get outbid ill let you know. right now im winning the bid. what kind of characteristics does the cam have? running, sloppy???
Hope you aren't paying much. I got mine for cheap. It idles good, and makes a little bit of power, but the powerband is up in the RPM's a little. I ran it with the stock converter etc.
bbowerman
Jul 26, 2015 10:57 PM
