cam 4 a lq9
Old Aug 2, 2009 | 02:45 AM
RickLowpez's Avatar
Default cam 4 a lq9
is a 222/224 581/581 112 to small to make good power on a rcsb 2wd with full bolt ons,lq9 6.0,fast 92mm,410,4k stall yank.im thinkin of running this cam but maybe upgrading the heads stock(317) to some prc2.5. well see if any one has a similiar set up or has ran a cam of similiar specs on a same set up let me know how its worked out. thanks for ur time
Old Aug 2, 2009 | 12:57 PM
ap2002's Avatar
I would go with a bigger cam with that setup... something in the low-mid 230's
Old Aug 2, 2009 | 01:27 PM
Sizzle Chest's Avatar
You have the stall/gears/intake to go much bigger especially if a nice set of heads is in your future. I have a very similar set up except with trick flow heads and I run a 227/235/615/620/111. Even that is on the small side.
Old Aug 2, 2009 | 04:39 PM
1989k1500's Avatar
With that converter and gear you would be fine with something in the mid to high 230s. IMO
I would get something with duration in the high 230s if it were mine. And depending on how the heads flow probably quite a bit of lift.
Old Aug 2, 2009 | 05:17 PM
D_reks{5.3}'s Avatar
When did you pick the lq9 up rick?
Old Aug 2, 2009 | 06:39 PM
RickLowpez's Avatar
well just got one. and got some goodies with it like a fast 92mm. so now need a cam
Old Aug 3, 2009 | 11:44 AM
Siiiiicck.. Hurry and get a cam in there.. and then i wanna check it out..
Ima be visitin Jim here in the next couple weeks, Finally time for my cam
Old Aug 3, 2009 | 01:21 PM
LsxCody's Avatar
A cam in the 230s would be great. I would upgrade heads too
Old Aug 3, 2009 | 03:31 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
yeah i def agree with what everybody else says get a cam in the low to mid 230s duration
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
Denali08
Aug 9, 2015 04:34 PM
Aboss
Jul 9, 2015 10:28 AM
