Btr Truck Torque Cam
Old Mar 17, 2020 | 06:41 PM
  #31
RedXray's Avatar
100% Redneck
Originally Posted by Parkboy
Low end torque is most important to me. How do you think the cam below would do compared to the btr cam? I've also been eyeing the cam motion 6.0 stage one 204/212 cam are you familiar with that cam?
Cam Motion has the best camshaft cores in the industry. They grind most BTR, Tick Performance and many other companies camshafts. Call Cam Motion or use the form on their site and let them spec out a custom grind for your application. Most of these different cam specs are so close, to be honest you're kinda splitting hairs and would never tell the difference in performance if you swapped most of them in. I recently swapped a 228/230 .585 .585 112* for a Cam Motion 222/232 .595 .587 108* . It ran and idled perfect on the old tune, bringing the power in just a bit sooner. There was hardly any change in drivability except for wide open throttle, the torque came in sooner and power fell off sooner... just as expected.
Old Mar 18, 2020 | 10:53 AM
  #32
Parkboy's Avatar
Originally Posted by 68Formula
Hard to say without the advertised specs. Based on the just the .050" it could have a slight advantage, however there's no guarantee since advertised can play a bigger role at low speed operation. For sure it will give up a strong amount of mid and top end. In general I shy away from cams that don't share both advertised and 0.050" values unless they have dyno data with detailed engine configuration to back up the results (Texas Speed for example).
Here is the advertised duration for the cam.
Duration @ .006'' would be...
261/269
Old Mar 18, 2020 | 03:36 PM
  #33
68Formula's Avatar
261/269
In the 2000-2500rpm range you might see about 5lbs-ft or so different (just a handful). You wouldn't even feel it. From 3000rpm up it'll quickly lose steam while the BTR will come on strong in comparison. I have nothing against Cammotion Cams (as a matter of fact, I love that they offer specific cams for different displacements, and they offer two core materials depending on how durable you want the lobes). But in this case the BTR pretty much runs the same down low while extending the torque curve significantly more.
Old Mar 18, 2020 | 09:09 PM
  #34
Jake Wade's Avatar
You want the BTR Stage 1 truck cam. Check out Richard Holdener channel on YouTube. Or, just get Cam motion to grind you a cam with those specs. No extra charge and you will have it within a week.
Old Mar 19, 2020 | 05:34 AM
  #35
68Formula's Avatar
Just a quick note to that Holdner's testing. His review of the BTR cams (tested on a 5.3L) I believe was prior to the release of the new version "V2" and has slightly different specs. The BTR V2 should perform even better across the power range.
Old Mar 23, 2020 | 07:32 PM
  #36
tglandon's Avatar
very interesting thread...
I have a 2001 2500HD CCSB 6.0 LQ4 towing a 38 ft 5th wheel. it is Magnuson supercharged mp112hh w/4.88 gears. i had a 26 ft trailer 8k and it pulled it great. Now it is a 12k 5th wheel. I need more help between 2000-3500. I am thinkin about this one. What makes a good supercharger tow cam??
Vinci st2 perf/tow
DUR @ .050" 208*/ 216*
LIFT .530 / .530
LSA 115*
5A
Old Mar 26, 2020 | 10:16 AM
  #37
Summitracing's Avatar
LS1Tech Sponsor
tglandon,
That sounds like a nice tow rig. You should create your own thread for a cam recommendation so this thread doesn't get hi-jacked. The community will be sure to jump in on your thread.
lxcoupe
Oct 29, 2019 03:38 AM
Jake Wade
Oct 3, 2019 04:36 PM
bearden86
25
Nov 1, 2015 07:12 PM
5.3parts
Jul 1, 2015 03:25 PM
