Btr Truck Torque Cam
#31
#32
Hard to say without the advertised specs. Based on the just the .050" it could have a slight advantage, however there's no guarantee since advertised can play a bigger role at low speed operation. For sure it will give up a strong amount of mid and top end. In general I shy away from cams that don't share both advertised and 0.050" values unless they have dyno data with detailed engine configuration to back up the results (Texas Speed for example).
Duration @ .006'' would be...
261/269
#33
In the 2000-2500rpm range you might see about 5lbs-ft or so different (just a handful). You wouldn't even feel it. From 3000rpm up it'll quickly lose steam while the BTR will come on strong in comparison. I have nothing against Cammotion Cams (as a matter of fact, I love that they offer specific cams for different displacements, and they offer two core materials depending on how durable you want the lobes). But in this case the BTR pretty much runs the same down low while extending the torque curve significantly more.
#35
Just a quick note to that Holdner's testing. His review of the BTR cams (tested on a 5.3L) I believe was prior to the release of the new version "V2" and has slightly different specs. The BTR V2 should perform even better across the power range.
#36
very interesting thread...
I have a 2001 2500HD CCSB 6.0 LQ4 towing a 38 ft 5th wheel. it is Magnuson supercharged mp112hh w/4.88 gears. i had a 26 ft trailer 8k and it pulled it great. Now it is a 12k 5th wheel. I need more help between 2000-3500. I am thinkin about this one. What makes a good supercharger tow cam??
Vinci st2 perf/tow
DUR @ .050" 208*/ 216*
LIFT .530 / .530
LSA 115*
5A
Vinci st2 perf/tow
LIFT .530 / .530
LSA 115*
5A
#37
tglandon,
That sounds like a nice tow rig. You should create your own thread for a cam recommendation so this thread doesn't get hi-jacked. The community will be sure to jump in on your thread.
5.3parts
Jul 1, 2015 03:25 PM
