Broken 5/16 dowel in block
Old Sep 3, 2019 | 08:59 AM
Chuy05's Avatar
Originally Posted by madmann26
LOL.
As long as one doesn't break one they work great....but then there is that .005%.
What are the odds I fall into that category. Hell I might go buy a scratch off with that luck haha
Old Sep 3, 2019 | 09:18 AM
madmann26's Avatar
I would say pretty high atm.
Old Sep 3, 2019 | 10:55 AM
kaze_v8's Avatar
No.
Metal or wood dowels?
You *might* be able to take the intake/valley cover off and use a pick to move it out some.
Worse case, pull the heads. Pulling the heads on a truck isn't nearly as hard as people think. When I dropped a lifter during a cam swap, I had the passenger side head off in about 30 min. It took me longer to prep the block/head for new gaskets.
All you had to do was remove the heads? Sheesh youre a lucky man.. try damn near taking the entire bottom half off the engine while in the truck... on a 4WD truck!
Old Sep 3, 2019 | 04:31 PM
madmann26's Avatar
Yea. I was lucky. The lifter slipped past my dowel rod and landed on top of the crank.
I went to Autozone and got a flexible magnet and after about 30min, was able to pick it up and snake it out carefully.
Old Sep 3, 2019 | 05:12 PM
Chuy05's Avatar
I just removed the rear main seal (was going to replace it anyways) and I think I can push it through from the back side towards the front. I'll keep you guys posted
Old Sep 3, 2019 | 06:01 PM
TXsilverado's Avatar
hit the center of the rod with a small drill bit (barely smaller than a screw), then thread in a sheetrock screw and pull it out. if you just attempt putting a screw in the end, the wood will epand or crack.
Old Sep 3, 2019 | 08:08 PM
Chuy05's Avatar
Here is the fix to this devastating issue. I pulled the rear main seal and you can see the rear of the cam and right above it there is 2 oil galleys. I went ahead and put a oiled dowel in there pushed it out towards the front of the block grabbed it with a pair of vice grips and pulled the demonic dowel out.
Old Sep 4, 2019 | 12:13 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Makes these worth every penny...
https://www.powerhouseproducts.com/g...ning-tool.html
Old Sep 5, 2019 | 08:25 AM
Alvin@PCMofNC's Avatar
Truck Sponsor
Glad you got it fixed. What a crazy story!
Old Sep 5, 2019 | 09:47 AM
Chuy05's Avatar
I'm not going to lie I lost a couple of hours of sleep.
bull0109
Aug 12, 2013 07:04 AM
RcrX
Nov 2, 2010 09:56 AM
Tootall
14
Mar 14, 2010 05:42 PM
coyote79
Jan 4, 2007 09:14 PM
