Cam Swap V 6 - who's done it
Old Mar 11, 2010 | 03:25 PM
Tootall's Avatar
Default Cam Swap V 6 - who's done it
yeah I know that it's a waste of time and money . . . but this guy is dead set on it.
The truck is a 2007 Silverado with the 4.3.
Are these motors still using the "balanced shafts"
Old Mar 11, 2010 | 03:42 PM
SILVERBIRCH's Avatar
I have a freind that wants to do the same to his v6 4.3 pretty much just for shitz and giglez.
Hey Matt what would be a good cam for the 1998 v6 4.3 engines?
Old Mar 11, 2010 | 03:48 PM
Tootall's Avatar
someone made a "super 6" package a while back for the 3.8 V6 camaros a while back . . . Isky doesn't, Lunati kinda does . . . and comp's phone has been busy today.
still looking . . . .
Old Mar 11, 2010 | 04:12 PM
Tootall's Avatar
I found this one . . . but there's no telling if it'll fit
http://www.summitracing.com/parts/CCA-K09-430-8/
Old Mar 11, 2010 | 04:17 PM
Tootall's Avatar
here's the same 4.3, but a few years older
http://www.hotrod.com/techarticles/e...o_results.html
still not worth it
Old Mar 12, 2010 | 12:59 PM
texasbullseye89's Avatar
Aren't they still the same blocks and internals from way back when?
Old Mar 12, 2010 | 02:20 PM
SilvyBlack02's Avatar
0.350 lift lobe will be the limit unless you want to nail the stock link bars go right ahead. It's pretty much worthless to cam a balance shafted 4.3.
Even HotRodMag ditched the plan on the balance shaft engine and did an earlier I think 89 or so 4.3.
Older versions are odd fires 96 and up are even fire. Crank is diffrent along with some other things.
Old Mar 12, 2010 | 02:23 PM
Wont fit, same thing HotRodMag tried on their 4.3 build again, it will hit the link bars.
Old Mar 12, 2010 | 03:22 PM
So i guess its better the keep the stock cam on a 4.3?
My friend has a 98 rcsb 4.3 vortec with cai intake, exhaust, 2600 stall, servos and wheatley tune and i got to say i was very impressed when i rode with him one day.
We were wondering how much of a diff. A cam and headers would do on it?
Old Mar 12, 2010 | 03:56 PM
1Bear's Avatar
I don’t know about being worthless and while you wouldn’t go with anything over .350 lobe lift or .525 valve lift, the heads will give up way before that anyway. GM used to offer two cams for the even-fire 4.3’s, I don’t even know if they are actually even available any more, but they were (part # 10051147) 222/222 .447/.447 114 and the other was (part # 10134321) 224/224 .450/.460 112. The 1st was listed as a V6/90 version of the old L79 small block cam for use in the 4.3L even-fire engine. The 2nd was listed as a high performance street and marine cam for use in the 4.3L even-fire engine. We are talking about cams here that were designed quite a few years ago, so I’m sure that while they would work decent even if they are still available, I would imagine that there are more current technology cams available. Of course the market isn’t the best for these animals, so technology may not be moving forward for them much. You may find one of the GM cams setting on a shelf somewhere if they are no longer listed new.
