Bore a 5.3L block out to 5.7L?
Old Jan 28, 2006 | 04:42 PM
  #21
TurboGibbs's Avatar
ls1(5.7),6.0 and 5.3 have the same crank and rods. You just need ls1 pistons.
Old Jan 28, 2006 | 05:28 PM
  #22
GoldenVelvet's Avatar
Originally Posted by Richard@WCCH
It usually varies between $75.00-125.00 for boring and honing the truck blocks. Sonic checking the bores can run an additional $75.00-100.00.
Richard
Richard,
Just wondering... Do you guys to block work too or heads exclusively?
Old Jan 28, 2006 | 10:54 PM
  #23
Richard@WCCH's Avatar
FormerVendor
Originally Posted by GoldenVelvet
Richard,
Sorry, we just handle cylinder heads. We do have a couple of shops in my area that handle the block work though. Let me know if you need any help and I'll see what we can do.
Richard
Old Jan 28, 2006 | 11:07 PM
  #24
1SlowHoe's Avatar
Destroyer of Transmissions
Reading this thread makes me want to ask a quick question. I have a 5.3 with a broke #7. In theory, I could:
Bore out to a 5.7
Use the stock crank
Add Katech or equivalent rod bolts
Forged rods/Forged dished pistons
Low C/R heads (say 9 to 1)
And boost the **** out of it
How much boost could it handle, say 20psi?
Would this setup be stronger than the 6L with 8-10psi that I am running now?
Sorry to hijack
Old Jan 29, 2006 | 03:43 AM
  #25
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Refer to CurtD's dyno of a stock 5.3 with forged pistons 650hp with a turbo aint too shabby either way the radix will ahve to go
Old Jan 29, 2006 | 03:59 AM
  #26
Richard
PM sent
Old Jan 29, 2006 | 11:29 PM
  #27
5.7 and 5.3 use the same crank? If that is correct then why not bore it
Old Jan 30, 2006 | 12:47 AM
  #28
FormerVendor
Bore out to a 5.7
Use the stock crank
Sorry to hijack
This certainly can be done and for a reasonable price. All the iron blocks are tough as nails and can handle big engine loads. You'll want to look for a pair of 5.7l heads to swap out for the smaller chamber 5.3l heads. You get a larger intake valve and a larger chamber by using the 5.7l heads.
The 6.0l engine still has the 5.7l beat in the torque department, but the gap is a lot closer than comparing a 5.3l to a 6.0l. The key is to take advantage of the larger intake valve that the 5.7l and 6.0l heads offer.
Good luck,
Richard
zblee
Nov 11, 2015 12:41 AM
mikeyjm1
17
Oct 29, 2015 11:04 PM
kalikid06
20
Oct 13, 2015 07:37 AM
dantheman1540
Sep 15, 2015 08:28 PM
